One Inch Squared - Portable Headphone Amplifier
Portable headphone amplifier with built in LiPo battery charger.
wwww
Portable headphone amplifier that runs on a single cell LiPo battery (3.7V) and features a LiPo battery charger on board.
I chose the Texas Instruments LM4881 audio amplifier because it requires a minimum number of external components and features digital volume control. The total cost of components for a single amplifier is $21.99 ($16.99 for components from Digikey + $5 for PCB from OSH Park)
  • 1 × LM4881 Audio ICs / Audio Amplifiers
  • 1 × ne555psr Clock and Timer ICs / Timer ICs
  • 1 × 180k resistor 0603
  • 1 × 150k resistor 0603
  • 1 × 1uF capacitor 0603 Electronic Components / Misc. Electronic Components
View all 25 components
  • Choosing an Amplifier IC
    ww12/20/2015 at 23:41 0 comments
    I've considered numerous amplifier IC's, but I settled with the Texas Instruments' LM4811. The IC's small footprint and low number of external components required made it the perfect candidate for a size restricted design. The LM4811 also featured digital volume control, which means I won't need to include a clunky potentiometre to provide volume control! However, TI suggests using a microcontroller to handle the digital volume control. Microcontrollers are expensive and need to be programmed, so I came up with an alternative, which I will explain in a later log.
    http://www.ti.com/lit/ds/symlink/lm4811.pdf
View project log
Andrew wrote 11/24/2021 at 22:50 point
I know this is an old project, but how far did you get? Can you share the Eagle Files? Thinking of doing my own around the LM4811. Thanks!
Blecky wrote 12/07/2015 at 01:34 point
Just a friendly reminder to please upload your design documents by 23:59 UTC on Dec 8, 2015 to be in the running for #The Square Inch Project!
alpha_ninja wrote 12/02/2015 at 00:41 point
This is your one-week reminder to upload design documents: https://hackaday.io/project/7813-the-square-inch-project/log/28566-design-deadline
