As you could have noticed @davedarko and I did each built an ESP8266 development board. Because they are very similar I could copy his idea of a display shield. In his project #ESP8266 RFid reader you can see his way. I did rebuilt this idea to fit to my #ESP8266 (ESP-07/12) Dev Board (rev1-2). It should be the same display. I did use this library and the Arduino IDE to program the ESP.
The shield is made out of cheap prototype board, wires, solder tin and some pin headers:
Together with display and ESP-board it look like this:
I usually design these little prototype board also with eagle, so If you are interested in the "layout" of the prototype board (the blue layer is top in this case):
I look forward to replicating this sometime soon. I have both of your ESP boards so it would be a welcome addition :-)
woohoo :) Looks good!
