SAME70 USED SIGNALS
03/21/2018 at 16:06 • 0 commentsThe list of signals used in the projects, I didn't describe them before, while using the schematics.
They are eigther exposed using connectors, or simply linking modules.
DRONI SAME70Pi / 1.ELECTRONICS / REMOTE CONTROLLER
03/21/2018 at 00:38 • 0 commentsThe idea is to have a hackable remote controller with a bunch of functionnalities without constraints on the real time transmission for manual control.
Again there will be SAME70 every where!
The remote controller will have two PCBs TOP and BOTTOM, same principle.
Only this time we put all the power, calcullation and communication modules in the BOTTOM PCB.
We the TOP PCB for buttons/leds/stick .
DRONI SAME70Pi / 1.ELECTRONICS / BUZZER & MISC
03/21/2018 at 00:23 • 0 commentsBZZZZZZ
I also added a connector for 11v1 in case I need to power a camera with analog feed transmitter, or simply a feed transmitter to the Compute Module.
DRONI SAME70Pi / 1.ELECTRONICS / DC CONVERTERS (5V0/3V3)
03/21/2018 at 00:19 • 0 commentsThe PCB BOTTOM provides 5V0 and 3V3 from the LiPo.
I use a bench of DC converters for that.
I put filters at the input of the DC converters to avoid the noise coming from the motors consumption. -
DRONI SAME70Pi / 1.ELECTRONICS / PCB BOTTOM LiPo CELL MEASURE
03/21/2018 at 00:16 • 0 commentsTo have the possibility to measure the remaining power of the LiPo it is more accurate to measure the voltage of each cell in parallel with the current.
A simple algo regarding the typical V=f(I) of the LiPo will give an idea about the remaining charge.The voltage of the cells, the current and voltage provided by the LiPo are sent to the PCB TOP using a 6pins connector.
DRONI SAME70Pi / 1.ELECTRONICS / PCB BOTTOM CURRENT SENS
03/21/2018 at 00:06 • 0 commentsTo measure the current provided by the LiPo we use the INA169 chip with a 0.001 resistor.
We measure also the voltage.
It is configured to select a range between 0-50A. -
DRONI SAME70Pi / 1.ELECTRONICS / PCB BOTTOM POWER DISTRIBUTION
03/21/2018 at 00:04 • 0 commentsThe 5V0 voltage provided by the PCB BOTTOM is behind a filter.
The PCB BOTTOM provides 4x5V0.
There are multiple DC converters due to current limitation for each.The PCB bottom provides the voltage to the motors.
It has a current sensors using a 0.001 ohm resistor with INA aplifier.
It provides the voltage of the 3cells of the LiPo to the PCB TOP.
DRONI SAME70Pi / 1.ELECTRONICS / PCB-TOP POWER USE
03/20/2018 at 23:50 • 0 commentsHere is the interfaces regarding the power needs/uses and the front sens connector.
It describes the connector used in the TOP PCB.There are mainly three types of connectors:
- JST/Molex 1.25mm like 6p
- JST/Molex 1.25 like 3p
- PFC connectors for the RPI CAM sockets and for the front sens panel
The power of the RPi CAMs are not represented, they are directly distributed by the compute module. -
DRONI SAME70Pi / 1.ELECTRONICS / PCB BOTTOM DESIGN (Update)
03/20/2018 at 11:40 • 0 commentsHere is the PCB BOTTOM that handles the power distribution.
It has a current sensor, a buzzer, a bunch of DC converters and connectors, and the fixations of the Pi CAM!
Th
DRONI SAME70Pi / 1.ELECTRONICS / PCB TOP DESIGN (Update)
03/18/2018 at 19:58 • 0 commentsI took into account the dimensions of all the sensors, sockets, arms,...
The initial view is slightly modified.
I moved a little fast on the PCB to have an initial version to make some iterations and verifications in parallel.
Il will give more details about the angles of the arms in another Log.
I just finished the first draw of the PCB TOP that handles the computation and the communication.
