Prescaler mod 5
A project log for Yet Another (Discrete) Clock
I HAD to finally do this basic "exercice de style" in digital electronics, using some hundreds of transistors and diodes...
yann-guidon-ygdesYann Guidon / YGDES • 05/28/2016 at 08:40•2 Comments
The "KCL structure" (covered there) is such a nice, regular circuit but it requires a mod 5 prescaler to convert the 18KHz source to 3600Hz. I have tried to make such prescaler but I was not satisfied.
5 is such an "inbetween" number, just after 4 (which requires 2 FlipFlops) and 6 (which requires 3 FF but is very easy to do with a Johnson counter). The previous approach with a reset adds nagging timing issues. So I went back to the sketchbook and made a few diagrams. I ended up with the following circuit with 3 10TFF and one NOR gate (with complementary output).
This is not an absolutely minimal circuit, when counting transistors, but it's simple and totally synchronous, which reduces problems and debugging at high speed. No reset is needed, which also simplifies the design, and it gracefully recovers from errors.
This is actually a "modified Johnson counter", I started with a mod 6 counter and removed one state.
1 2 3
0 0 0 #0
1 0 0 #1
1 1 0 #2
1 1 1 #3 => removed
0 1 1 #4
0 0 1 #5
The new succession of states becomes:
1 2 3
0 0 0 #0
1 0 0 #1
1 1 0 #2
0 1 1 #3
0 0 1 #4
Now notice that the state 1 is added in FF1 only when FF2 and FF3 are 0. Yes, it's a NOR gate !
Drawing the complete state machine gives the following diagram:
The absence of forbidden state (as in a LFSR) or subcycles of lower size makes a RESET input useless.
Implementing a NOR gate requires 2 P-FET and 2 N-FET, the inverter adds another complementary pair so the "cost" is 6 transistors. It's not the absolute best solution but I think it's so elegant that I adopted it :-)
K.C. Lee wrote 05/28/2016 at 10:23 • point
Got an idea: Use a FF to delay the carry of a divide by 4 for one clock cycle and also use that output as a reset to the counter.  Yes it requires a reset, but otherwise no combinational logic.
Yann Guidon / YGDES wrote 05/28/2016 at 10:26 • point
That was my initial idea, this is what FF3 does at https://hackaday.io/project/9376-yet-another-discrete-clock/log/38239-the-kcl-structure
But i was not satisfied with this method...
