1Step 1
Download"Jessie" image and burn to SD Card.
2Step 2
From here we could follow instructions over @LearnAdafruit or keep reading here.
Download THIS new Kernel. Thanks to @adafruit @AdafruitIndustries @limor
Move the kernel file to the boot directory of your "Jessie" SD card.
Insert SD Card in the Pi Zero and power on. -
3Step 3
Now we are going to :
- Install the new kernel we downloaded.
- backup and install new kernel.
- Install Overlays & Modules.
- update the module and reboot
We will need to run the following commands.
cd ~ sudo mv /boot/gadgetkernel.tgz tar -xvzf gadgetkernel.tgz sudo mv /boot/kernel.img /boot/kernelbackup.img sudo mv tmp/boot/kernel.img /boot sudo mv tmp/boot/overlays/* /boot/overlays sudo mv tmp/boot/*dtb /boot sudo cp -R tmp/boot/modules/lib/* /lib sudo nano /etc/modules
after the last command the text editor will show up so we we will addg_midi
and then save the file. -
4Step 4
Done! we just need to connect PiZero to PC. Now on your computer there will be a new MIDI device . Check the Windows Device Manager.
5Step 5
Software Install:
piStudio Runs with LMMS so we need to Install this to the piZero. Open up a terminal and run the command:
sudo apt-get install lmms
and we are Done! For now. -
6Step 6
AUDIO:
In order to be able to use the phatDac we will need to set it up.
in order to do this we will need to:
- connect to the internet.
- bring up the terminal.
- Run this code:
curl -sS get.pimoroni.com/phatdac | bash
This will run the automated installer provided by PIMORONI.for manual install we can follow the instruction ove at the POST " Setting up pHAT DAC".
7Step 7
MIDI:
In order to get Midi working we need to boot up the Pi, and type this in a terminal:
sudo nano /boot/config.tx
We will add these two lines:
init_uart_clock=2441406 init_uart_baud=38400
now save (Ctrl+0) and exit (Ctrl+x).Next, edit the cmdline.txt and inittab.txt to disable the Pi's shell from UART so the port is free for MIDI access. Back-up each file :
sudo cp /boot/cmdline.txt /boot/cmdline.bak sudo cp /etc/inittab /etc/inittab.bak
Lets edit the cmdline.txt:
sudo nano /boot/cmdline.txt
remove any mention of ttyAMA0,115200 such as “console=ttyAMA0,115200” and “kgdboc=ttyAMA0,115200”. It should say "console=tty1" after you've edited it. Add bcm2708.uart_clock=3000000 to the first line in case it's not already there, so now it should look like this:dwc_otg.lpm_enable=0 bcm2708.uart_clock=3000000 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
Save and exit, then edit the inittab.txt
sudo nano /etc/inittab
Now look for the line at the bottom that says “ttyAMA0” and remove it or put a hash in front of it like this:
#ttyAMA0
Save and exit, and then restart your Pi. Now the Pi should be able to receive and send communication at 31250 baud, but we need to install a program to handle the MIDI signals. Time to do a little ditty for TTYMidi, a bit of software that creates a serial to ALSA interface on your Pi. Type the following commands into the Pi terminal to download and install ttymidi:
sudo apt-get install libasound2-dev wget http://www.varal.org/ttymidi/ttymidi.tar.gz tar -zxvf ttymidi.tar.gz cd ttymidi/ make sudo make install
Reboot the Pi.
Would this work with any other pi (i.e., 3+ or 4), or is it specific to the Zero?
All that is very nice, but how you will connect the connecters XLR and all others to the raspberry ? I am not sure how you did it. can you help me with that please ? Thanks.
Nice, how are you planning on connecting the SATA drive?
USB Hub/Usb Hdd Enclosure
