Raspberry Pi Zero cap rail enclosure
USB hub, wide range power supply, protoboard and din rail enclosure for the Raspberry Pi Zero
RasPiBox Zero is an accessory for the Raspberry Pi Zero. The heart is an additional pcb with integrated USB hub, voltage regulator and breadboard. It fits together with the PiZero in a 3 module DIN rail enclosure.
Overview:
  • milled 3 module DIN rail enclosure
  • assembled pcb with socket to plug a Raspberry Pi Zero
  • integrated voltage regulator (input voltage 9..35V via 2 was terminal block)
  • integrated 4 port USB hub
  • breadboard / proto board for own circuits
  • marked SPI, I2C and UART connectors beside the breadboard area
  • 2x 2 way terminal blocks to connect external componets to the breadboard
By the way it is completely impossible to buy an Raspberry Pi zero at the moment. Thats the reason why we have tested the hardware only with an A+ until now.
We will post circuit diagram, videos and other pictures soon as possible. Check also our website for more information.
Datasheet RasPiBox zero Rev A.pdf
This document gives you an overview about the features of the project
Adobe Portable Document Format - 154.90 kB - 02/06/2016 at 15:04
Preview
View all 2 project logs
hwhardsoft wrote 02/15/2016 at 06:30 point
Thx for the RPI0 Craig - this helps a lot!
Craig Hissett wrote 02/13/2016 at 20:26 point
Glad to see this in the contest!
Hope that Pi Zero is coming in handy :-)
