module upload for kernel 4.4.48+
03/04/2017 at 01:05 • 0 commentsUploaded kernel module for kernel version 4.4.48+, which corresponds to 2017-02-16-raspbian.
updated compiled module
12/29/2016 at 19:57 • 0 commentsKernel module is now for Raspbian 2016-11-25
module updated to use device tree
05/03/2016 at 03:46 • 0 commentsModule now gets divisors and translation table from device tree overlay. This means that you won't have to recompile the module for non-Model M keyboards.
Updated files and changed instructions accordingly.
03/20/2016 at 22:46 • 0 commentsCompiled module is now for raspbian-2016-3-18.
fixed a few things
03/06/2016 at 13:46 • 0 commentsFixed the RXD pin symbol: it was pointing the wrong direction, as pointed out by a sharp reader.
I clarified the description of how the circuit works. There seems to have been some confusion - I simply use the UART to read the keyboard bitstream, which happens to be standard serial in most cases. No fancy polling code was necessary.
Also added schematic file.
uploaded files
02/29/2016 at 23:44 • 0 commentsUploaded new sources and compiled module for Raspbian 2016-2-29
initial posting
02/29/2016 at 05:02 • 0 commentsCopied from the project page at my website, then edited a bit.
