2N4401: NPN Transistor, Pinout, Datasheet
04/09/2022 at 02:27 • 0 comments2N4401 Description
The 2n4401 is a bipolar junction transistor with an NPN junction that is used for general purpose amplification and switching. Conduction is carried out by both charge carriers, i.e. electrons and holes, in a bipolar junction transistor. However, electrons will be the majority charge carriers.
2N4401 Features
The collector current (IC) is 500mA on a continuous basis.
The voltage between the collector and the emitter (VCE) is 40 volts.
The collector-base voltage (VCB) is set to 60 volts.
6V is the Emitter Base Breakdown Voltage (VBE).
100MHz is the transition frequency.
To-92 package is available.
General-purpose NPN Transistor
High DC Current Gain (hFE), typically 80 when IC=10mA
2N4401 Pinout
![无]()
![无]()
2N4401 CAD Model
Symbol
![无]()
Footprint
![无]()
3D Model
![无]()
2N4401 Equivalents
Part Number Description Manufacturer 2N4401RLRETRANSISTORS Small Signal Bipolar Transistor, 0.6A I(C), 40V V(BR)CEO, 1-Element, NPN, Silicon, TO-92 Motorola Semiconductor Products 2N4401TFRTRANSISTORS 600mA, 40V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92, LEAD-FREE, TO-92, 3 PIN Rochester Electronics LLC 2N4401D74ZTRANSISTORS Small Signal Bipolar Transistor, 0.6A I(C), 40V V(BR)CEO, 1-Element, NPN, Silicon, TO-92 Fairchild Semiconductor Corporation 2N4401BUTRANSISTORS 600mA, 40V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92, LEAD FREE, TO-92, 3 PIN Rochester Electronics LLC 2N4401TATRANSISTORS NPN Bipolar Junction Transistor, TO-92, 2000-FNFLD onsemi 2N4401_J05ZTRANSISTORS Small Signal Bipolar Transistor, 0.6A I(C), 40V V(BR)CEO, 1-Element, NPN, Silicon, TO-92, LEAD FREE, TO-92, 3 PIN Fairchild Semiconductor Corporation 2N4401RLTRANSISTORS 600mA, 40V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92, CASE 29-11, TO-226AA, 3 PIN onsemi 2N4401RLRAGTRANSISTORS 600mA, 40V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92, LEAD FREE, CASE 29-11, TO-226AA, 3 PIN Rochester Electronics LLC 2N4401RLRPTRANSISTORS 600mA, 40V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92, CASE 29-11, TO-226AA, 3 PIN Rochester Electronics LLC 2N4401-APTRANSISTORS Small Signal Bipolar Transistor, 40V V(BR)CEO, 1-Element, NPN, Silicon, TO-92, ROHS COMPLIANT, PLASTIC PACKAGE-3 Micro Commercial Components Specifications
Package / Case: TO-226-3, TO-92-3 (TO-226AA) (Formed Leads)
Packaging: Bulk
Operating Temperature: -55°C~150°C TJ
Voltage - Collector Emitter Breakdown (Max): 40V
Transistor Type: NPN
Mounting Type: Through Hole
2N4401 Applications
1. It has the ability to switch high-current loads (up to 500mA).
2. It can be used in a wide range of switching applications.
3. Controlling the speed of the motor
4. Inverter and other rectifier circuits
5. It can be employed in Darlington Pair.
2N4401 Package
![无]()
2N4401 Manufacturer
On Semiconductor (Nasdaq: ON) is a manufacturer engaging itself in reducing energy use. It features a comprehensive portfolio of power, signal management, and logic, custom solutions that are energy efficient. It acts as a world-class supply chain with high reliability and a network of manufacturing facilities, sales, offices, and design centers in key markets through North America, Europe, and the Asia Pacific regions.
2N4401 vs 2N3904
In every way, the 2N3904 and 2N4401 look to be quite similar parts. The 2N4401 has a greater current rating, but otherwise, they appear to be similar in pricing and other aspects.
2N4401 vs 2N2222
The 2N4401 transistor is extremely similar to the widely used 2N2222 NPN transistor. The 2N4401 and the 2N2222, on the other hand, have two major variances. When compared to 2N2222, the 2N4401 has a collector current limit of 500mA and power dissipation of 652mW, making it appropriate for medium loads, but it can also drive loads bigger than BC547.
Frequently Asked Questions In 2N4401
What is 2N4401?
The 2n4401 is a bipolar junction transistor with an NPN junction that is used for general-purpose amplification and switching. Conduction is carried out by both charge carriers, i.e. electrons...
Read more -
2SC945: Pinout, Equivalents, and Datasheet
04/02/2022 at 02:08 • 0 comments2SC945 Description
The 2SC945 is a high-frequency OSC NPN audio frequency amplifier transistor. It is an old Japanese bipolar audio NPN transistor, which has been widely used in high-frequency circuits for pre-amplification in amplifier applications.
![无]()
2SC945 Features
1. Power dissipation of 0.4Watts.
2. Collector current of 0.15A.
3. Collector-base Voltage: 60 volts
4. Operating and storage junction temperature range: -55°C to +150°C • Epoxy has a flammability grade of UL 94 V-0
5. Level 1 Moisture Sensitivity
2SC945 Pinout
![无]()
![无]()
2SC945 CAD Model
Symbol
![无]()
Footprint
![无]()
3D Model
![无]()
Specifications
Package:TO-226-3, TO-92-3 (TO-226AA) (Formed Leads)
Pin Count: 3
Packaging: Tape & Box (TB)
Transition Frequency: 150MHz
Number of Terminations: 3
2SC945 Equivalents
2SC2856TRANSISTORS, MPSA56/D26Z{OPTION18}TRANSISTORS, KSC2310-OTRANSISTORS, BC368-16TRANSISTORS, BSS38TRANSISTORS, ZTX455QTRANSISTORS, JC557ATRANSISTORS, BC546BRL1TRANSISTORS, ZTX450TRANSISTORS, BC546B-AMMOTRANSISTORS
Applications
1. Switches with low current
2. Pre-amplifiers
3. Low-power motor H-bridge circuits
4. Circuits for audio frequency amplifiers
5. Oscillator circuits
Where To Use 2SC945
Because it has a low base voltage of 5V, it can be easily controlled by an MCU/MPU if used as a switch. It can switch loads of up to 50 volts. With its complementary A733 PNP transistor, it can also be used as an oscillator.
Package
![无]()
Manufacturer
Founded in 1991, Micro Commercial Components Corp. (MCC) is a manufacturer of high-quality discrete semiconductors to the consumer markets. It provides diodes, rectifiers, transistors, MOSFETs, voltage regulators and protection devices.
Datasheet
https://pdf.easybom.com/r/datasheets/microcommercialco-2sc945grap-datasheets-7531.pdf
Check out more details on: https://www.easybom.com/blog/a/the-introduction-of-2sc945
PN2222 Vs. 2N2222: They Are Equivalents In Most Cases
03/24/2022 at 03:33 • 0 commentsPN2222 Overview
The PN2222 is a popular NPN bipolar junction transistor that is used for common low-power intensification or swapping circuits. It is designed for low to intermediate current, modest power, and intermediate voltage, and it may operate at a moderately higher speed.
2N2222 Overview
The 2N2222 is a typical NPN bipolar junction transistor (BJT) used in low-power amplifying or switching applications. It is intended for low to medium current, low power, medium voltage, and relatively fast operation. It was originally created in the TO-18 metal container shown in the image.
What Is 2N2222 Used For?
PN2222 Pinout
![PN Pinout.jpg PN Pinout.jpg]()
2N2222 Pinout
![2N2222 PINOUT.jpg 2N2222 PINOUT.jpg]()
PN2222 CAD Model
Symbol
![pn symbol.png pn symbol.png]()
Footprint
![pn footprint.png pn footprint.png]()
2N2222 CAD Model
Symbol
![22 symbol.png 22 symbol.png]()
Footprint
![22 footprint.png 22 footprint.png]()
3D Model
![22 3d.png 22 3d.png]()
PN2222 Equivalents
Part Number Description Manufacturer PN2222TFTRANSISTORS 600mA, 30V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92, LEAD FREE, TO-92, 3 PIN Rochester Electronics LLC PH2222TRANSISTORS Transistor, North American Philips Discrete Products Div PN2222-AMMOTRANSISTORS TRANSISTOR 600 mA, 30 V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92, BIP General Purpose Small Signal NXP Semiconductors PN2222/J18ZTRANSISTORS 500mA, 30V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92 Texas Instruments PN2222-T/RTRANSISTORS TRANSISTOR 600 mA, 30 V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92, BIP General Purpose Small Signal NXP Semiconductors PN2222/D81ZTRANSISTORS 500mA, 30V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92 Texas Instruments PN2222TFRTRANSISTORS 600mA, 30V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92, LEAD FREE, TO-92, 3 PIN Rochester Electronics LLC PN2222TARTRANSISTORS Small Signal Bipolar Transistor, 0.6A I(C), 30V V(BR)CEO, 1-Element, NPN, Silicon, TO-92, LEAD FREE, TO-92, 3 PIN Fairchild Semiconductor Corporation PN2222/D74ZTRANSISTORS 500mA, 30V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92 Texas Instruments PN2222/D28ZTRANSISTORS 500mA, 30V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92 Texas Instruments The Electrical Characteristics Of PN2222 And 2N2222
PARAMETER SYMBOL PN/2N2222 MIN MAX Collector-Snitter Saturation vCE(sat)* 0.4 Voltage 1.6 Base-Dnitter Saturation Voltage vBE(sat)* 1.5 2.6 D.C. Current Gain hFE * 100 500 Current Oain-Bandwidth Product 250 Collec Capac it ance Cob 8 Emitter-Base Capacitance Cib 25 Collector-Base Time Constant Cgbb' Noise Figure NF Input Impedance hie・ Voltage Feedback Ratio hre Small Si(<nal Current Gain hfe Output Admittance h°e td >span class="font0">Rise Time tr Storage Time Fall Time tf The Differences Between PN2222 And 2N2222
From above, we can see that there are lot of similarities between them. The two components are interchangeable under most circumstances, but there are just a few differences, like the packages they use are not the same type.
What Is The Difference Between SOT23 And SOT323?
03/21/2022 at 04:02 • 0 commentsSOT23 vs SOT323 Overview
SOT23 and SOT323 are both plastic and surface-mounted packages. SOT23 owns 3 terminals, 1.9mm pitch, 2.9mm x 1.33mm x 1mm body, while SOT323 boasts 3 leads, 1.3mm pitch, 2mm x 1.25mm x 0.95mm body.
SOT23 vs SOT323 Pinout
![PINOUT.jpg PINOUT.jpg]()
SOT23 and SOT323 Differences In Feature
1.Two-line bidirectional ESD protectionl For CAN-Bus applications and interface ESD protection
2. Compact SOT-323 and SOT-23 packages
3. Low package height:
-SOT-323: 1.1mm
-SOT-23: 1.2mm
4. AEC-Q101 qualified versions available
5. Working range:
-VCAN16A2: ±16V
-VCAN33A2: ± 33V
6. Low leakage current: <0.05μA
7. Low load capacitance typical CD:
-VCAN16A2: ±16V, <18.5pF at 0V
-VCAN33A2: ±33V, <9.7pF at 0V
8. ESD protection acc. IEC 61000-4-2:
-±30kV contact discharge
-±30kV air discharge
9. Soldering can be checked by standard vision inspection (AOI = automated optical inspection)
10. e3 – pins plated with tin (Sn)
The Parameters Differences In SOT23 And SOT323
![dimensions.jpg dimensions.jpg]()
Dimensions (mm) SOT23 SOT323 A 2.9 2.9 B 1.3 1.3 C D G 1.9 1.3 H J K L 0.95 0.65 S V From the image and the diagram, we can see that there are two different dimensions in SOT23 and SOT323: The length of G is 1.9mm and 1.3mm and L is 0.95mm and 0.65mm respectively. When using the packages, we should check whether these two dimensions fit the component or not.
The Package Outlines of SOT323 and SOT23
![sot23 package.png sot23 package.png]()
SOT23 Package Outline
![parameter23.png parameter23.png]()
The Parameters Of SOT23 Package
![sot323 package.png sot323 package.png]()
SOT323 Package Outline
![parameter323.png parameter323.png]()
The Soldering Differences in SOT23 and SOT323
Reflow Soldering
![REFLOW SOLDERING.jpg REFLOW SOLDERING.jpg]()
Wave Soldering
![WAVE SOLDERING.jpg WAVE SOLDERING.jpg]()
Conclusion
From above, we can know that there are a few differences between SOT23 and SOT323. For instance, the pitch of SOT323 is 0.6mm small than that of SOT23, and SOT323’s dimensions of body are smaller than SOT23’s, etc. There are various similarity between them, but we should check the detailed dimensions when using them.
NE5532 Vs. TL072: What Is The Difference?
03/21/2022 at 03:59 • 1 commentNE5532 Overview
The NE5532 is a high-performance, low-noise operational amplifier with twin channels. It outperforms most typical operational amplifiers, including 1458, in terms of noise performance, output drive capability, and small-signal and power bandwidths.
As a result, the device is particularly well-suited for use in high-quality and professional audio equipment, instrumentation and control circuits, and telephone channel amplifiers. For gains of one, the op amp is internally adjusted. If very low noise is critical, the 5532A variant is recommended because it has guaranteed noise voltage standards.
TL072 Overview
The TL072 is a high-speed J–FET input dual operational amplifier with well-matched high voltage J–FET and bipolar transistors in a monolithic integrated circuit. High slew rates, low input bias and offset currents, and a low offset voltage temperature coefficient characterize the devices.
NE5532 Pinout
![5532 pinout.jpg 5532 pinout.jpg]()
TL072 Pinout
![72pinout.jpg 72pinout.jpg]()
NE5532 Equivalents
Part Number Description Manufacturer TL082CDR2AMPLIFIER CIRCUITS Operational Amplifier, 2 Func, 20000uV Offset-Max, BIPolar, PDSO8, PLASTIC, SO-8 Motorola Semiconductor Products TL072ACNAMPLIFIER CIRCUITS JFET inputs, low input bias current STMicroelectronics UPC4560CAMPLIFIER CIRCUITS Operational Amplifier, 2 Func, 6000uV Offset-Max, BIPolar, PDIP8, 0.300 INCH, PLASTIC, DIP-8 NEC Electronics Group UPC1458CAMPLIFIER CIRCUITS Operational Amplifier, 2 Func, 6000uV Offset-Max, BIPolar, PDIP8, 0.300 INCH, PLASTIC, DIP-8 NEC Electronics Group MC1558UGAMPLIFIER CIRCUITS Operational Amplifier, 2 Func, BIPolar, CDIP8, LEAD FREE, CERAMIC, DIP-8 Motorola Semiconductor Products TL082MJGAMPLIFIER CIRCUITS IC,OP-AMP,DUAL,BIPOLAR/JFET,DIP,8PIN,CERAMIC Freescale Semiconductor MC4558L-D08-TAMPLIFIER CIRCUITS Operational Amplifier, 2 Func, 6000uV Offset-Max, BIPolar, LEAD FREE, DIP-8 Unisonic Technologies Co Ltd MC33178PAMPLIFIER CIRCUITS IC,OP-AMP,DUAL,BIPOLAR,DIP,8PIN,PLASTIC Freescale Semiconductor MC4558UAMPLIFIER CIRCUITS Operational Amplifier, 2 Func, 5000uV Offset-Max, BIPolar, CDIP8, CERAMIC, DIP-8 Motorola Semiconductor Products TA75071PAMPLIFIER CIRCUITS IC OP-AMP, 10000 uV OFFSET-MAX, 3 MHz BAND WIDTH, PDIP8, 0.300 INCH, 2.54 MM PITCH, PLASTIC, DIP-8, Operational Amplifier Toshiba America Electronic Components The Differences Between NE5532 And TL072 In Features
NE5532 Features:
• Small-Signal Bandwidth: 10 MHz
• Output Drive Capability: 600 , 10 VRMS
• Input Noise Voltage: 5.0 nV Hz (Typical)
• DC Voltage Gain: 50000
• AC Voltage Gain: 2200 at 10 kHz
• Power Bandwidth: 140 kHz
• Slew Rate: 9.0 V/s
• Large Supply Voltage Range: 3.0 to 20 V
• Compensated for Unity Gain
• Pb−Free Packages are Available
TL072 Features:
• High slew rate: 20 V/μs (TL07xH, typ)
• Low offset voltage: 1 mV (TL07xH, typ)
• Low offset voltage drift: 2 μV/°C
• Low power consumption: 940 μA/ch (TL07xH, typ)
• Wide common-mode and differential voltage ranges
– Common-mode input voltage range includes VCC+
• Low input bias and offset currents
• Low noise: Vn = 18 nV/√Hz (typ) at f = 1 kHz
• Output short-circuit protection
• Low total harmonic distortion: 0.003% (typ)
• Wide supply voltage: ±2.25 V to ±20 V, 4.5 V to 40 V
NE5532 needs lower noise voltage than TL072, the high slew rate of NE5532 is also lower than TL072.
The Differences Between NE5532 And TL072 In Applications
NE5532 Applications:
• AV Receivers
• Embedded PCs
• Netbooks
• Video Broadcasting and Infrastructure: Scalable Platforms
• DVD Recorders and Players
• Multichannel Video Transcoders
• Pro Audio Mixers
TL072 Applications:
• Solar energy: string and central inverter
• Motor drives: AC and servo drive control and power stage modules
• Single phase online UPS
• Three phase UPS
• Pro audio mixers
• Battery test equipment
The NE5532 outperforms the TLO72 in almost every aspect of audio...
Read more
