Project reveal.
04/17/2018 at 17:30 • 2 commentsWell, I just changed the project name from "Sputtering" to "Semiconductors @ Home"
I realized I was trying to hide from laughs/comparisons with Sam Zeloof, or worst, someone thinking I am somehow trying to "race" him into the first chip made at home.
Well, I am not.
I will get there when I get there, so, please, enjoy the ride in my low tech boat.
See ya!
Doc Ock
04/17/2018 at 14:33 • 0 commentsPrototyping an HVAC manipulator for the chamber, in style.
https://electronicmercenary.wordpress.com/2018/04/17/doc-ock/
Thunderdrome. (Lightning in a bottle)
04/03/2018 at 06:17 • 0 commentsBuilding the HV power supply for the sputtering machine.
Blog post:
https://electronicmercenary.wordpress.com/2018/04/03/thunderdromelightninginabottle/
The Chamber of Secrets (How It's Made edition)
03/31/2018 at 06:49 • 0 commentsBuilding a vacuum chamber, the strange way.
Blog post:
https://electronicmercenary.wordpress.com/2018/03/31/the-chamber-of-secrets-how-its-made-edition/
Charge that bitch up (practical plasmas on bad vacuum)
03/27/2018 at 08:17 • 0 commentsMaking plasma experiments with a not-so-good vacuum pump.
Blog post:
Glassworks!
03/27/2018 at 08:05 • 0 commentsBecause I am a cheap bastard that wants to use the endcaps of the vacuum chamber as Anode and Katode, instead of messing around with sparkplugs or similar, I need an electrical insulator for my vacuum pump, because the KF16 vaccum line is all metal. Otherwise, the pump would sit at 500V potential.
Buying a ceramic insulator is out of the question, and a glass insulator is expensive (could easily reach 100€, SUPPOSING that the selling company wants to do business with an individual) So, I bought borosilicate tube and set my lathe to slow cooking.
https://electronicmercenary.wordpress.com/2018/03/25/glassworks-preview/
https://electronicmercenary.wordpress.com/2018/03/26/glassworks-2-the-dos-and-donts/
Passing gas.
03/27/2018 at 07:29 • 0 commentsBuilding a KF16 flanged valve to inject Argon in the vacuum chamber at very small rates.
Blog post:
https://electronicmercenary.wordpress.com/2018/03/23/passing-gas/
HVAC or not HVAC, valve is the question.
03/27/2018 at 07:28 • 0 commentsAnalizing cheap R134a valves for HVAC tests.
Blog post:
https://electronicmercenary.wordpress.com/2018/03/19/hvac-or-not-hvac-valve-is-the-question/
Suck-Cess!
03/27/2018 at 07:27 • 0 commentsAbout vacuum pumps, what you can expect and what you should get. Also, double stage vacuum pump rebuild.
Blog post:
https://electronicmercenary.wordpress.com/2018/03/17/suck-cess/
Nixie
