The Mini Quadruped Mobile Robot
mePed is an awesome little open source quadruped robot which allows anyone to build their very own walking robot.
octect-stream - 664.38 kB - 09/21/2016 at 23:05
x-zip-compressed - 40.49 kB - 09/21/2016 at 22:59
ino - 16.19 kB - 09/21/2016 at 22:46
x-zip-compressed - 118.43 kB - 09/21/2016 at 22:45
AutoCAD DXF - 740.58 kB - 09/21/2016 at 22:45
View all 8 components
Do you have any videos of it walking?
Here's the video we did for our Kickstarter campaign: I'll try to shoot some more videos of it walking and an assembly guide soon. Thanks!
Hi Radomir,
Thanks for the suggestions, I'll have to look into the SG92R Servos! I hadn't given much thought to 3DOF Legs simply because I wanted to keep the servo count to a minimum to make it more affordable and reduce the buyout part count.
Hi, you might be interested in some of my experiments with #Tote.
From what I see in the pictures, I have some suggestions/questions:
* Try SG92R servos instead of MG90S. They are lighter, cheaper and stronger. They use carbon fiber gears instead of metal gears.
* Consider using plastic (acrylic or nylon) bolts to reduce the weight.
* Have you thought about going full 3dof?
Vishwajeet Narwal
Doan Hong Trung
Andrew R Gross
Roger Cobra
Yes, delete it Cancel
You are about to report the project "mePed", please tell us the reason.
