For soldering QFN and similar leadless packages, this preheat plate is really handy tool, as it allows for faster temperature ramp-up during reflow phase, introduces less strain in PCB and components during soldering and allows better temperature control than no preheat plate :-)
I designed this as a quick hack and use it for some time, but I feel like it could be improved, so I started project describing current state and document future development.
No rocket science involved here - I took 3mm thick piece of aluminium, sized 10x15cm and drilled holes for resistors.
I mounted the resistors with fair amount of thermal conductive compound and connected to two groups of three parallell resistors, forming 6,6Ohm resistor.
As a controller, I took one of my older projects (thermal controller for I2C temperature sensor) and brought analog input of PIC device to header, with 1,5k pull-up resistor, creating voltage divider with KTY84-130 temperature sensor under that white blob of high temperature epoxy.
The bodge wire is modification for analog resistive KTY84 sensor.
Everything is powered by 19V adaptor from old laptop computer, Those power supplies are quite powerful and you can get them very easily.
And it works, as expected. Notice the long cables. I was lazy to cut them short.
There is only single button to change temperature - there are presets for 0,80,90,100,110,120,130,140,150 degrees of celsius. You can cycle through those temperatures with the button, after pressing it the new temperature is on display for a second (yellow LED is on), then it changes to actual temperature (and green LED is on), so you can watch how it approaches the setpoint. Red LED indicates when heatplate is powered.
There is not much details in this log, as I don't expect anybody to build this thing, however, I uploaded design files on github, so anyone can get inspiration.
What's next?
I'm going to rebuild this, so it will not look as piece of junk.
This seems to be pretty useful. It gave me some more ideas about my heatplate for my printrbot simple I want to build and seems to be a nice heating plate for vaporizing acetone for ABS prints, or your tea or coffee ;) And I have never seen resistors in to-220 form before. Thank you for posting this :)
Thanks.
Yes, the heatplate could be used for different tasks, not being limited to just soldering preheat.Vaporizing acetone from ABS prints is something I didn't think about. Hackaday.io is nice place to share ideas.
Use a 3D Printer heat bed
