Why a Half Adder?
07/19/2018 at 21:43 • 0 commentsYou might wonder why we are building a half adder and what other kinds of adders there are. A half adder takes two bits in and produces two output bits, a sum and a carry:
A B Sum Carry 0 0 0 0 0 1 1 0 1 0 1 0 1 1 0 1 This is suitable for adding the first two bits of a multibit word. The reason you can't use it on subsequent bits is because it lacks an input for a carry bit from the previous stage. You really need a 3-bit adder. One that takes the two input bits and the carry from the previous bit. That's a full adder:
A B Carry In (C) Sum Carry Out 0 0 0 0 0 0 0 1 1 0 0 1 0 1 0 0 1 1 0 1 1 0 0 1 0 1 0 1 0 1 1 1 0 0 1 1 1 1 1 1 The full adder is almost -- but not quite -- two half adders. Typically, for a full adder you'll need two two-input XOR gates. One computes B+C and the other takes that sum and adds A to produce the final sum. There are several ways to compute the carry, but one way to do it is to realize that the carry out is true in two cases. The first is when A is 1 and B+C (that is, the sum from the first XOR gate) is also 1. That covers the rows above where A=1, B=0, C=1 and A=1, B=1, C=0. That leaves two rows uncovered: A=0, B=1, C=1 and A=1, B=1, C=1. If you think about it, the A must be a don't care because it can be either a 1 or a 0. So the second case is B=1 and C=1.
You can easily implement this with two AND gates and an OR gate. The schematic appears below and if you click the link you can try it in the excellent Falstad simulator (just click on the left side 1s and 0s to set the input you like). The bottom half adder handles the least significant bit (LSB). The carry output goes to the full adder for bit 1 through the carry input. That adder's carry output goes to the most significant bit (MSB) full adder.
You could implement this in Verilog for practice using gates, but in reality, Verilog will figure this out for you when you write something like:
module fulladder(output carryout, output [2:0] sum, input [2:0] a, input [2:0] b); assign {carryout, sum} = a+b; endmoduleNot only is this easier, but the FPGA tools will probably identify how to do this using parts of the FPGA specifically meant for things like carry propagation, allowing you to possibly get higher density and speeds than if you just specified things at a gate level. You can experiment with that in the simulator, if you like.
A Quick FPGA Glossary
06/24/2018 at 21:40 • 0 comments- Adder - See Full Adder and Half Adder.
- AND Gate - A gate who's output is 1 only when all inputs are 1.
- Blocking assignment - In Verilog, when an assignment occurs before any subsequent assignments (that is, it does not occur in parallel).
- Combinatorial Logic - Logic that does not rely on the previous state of the system to set the current output state.
- Exclusive OR Gate - See XOR Gate.
- Flip Flop - A circuit element that can take one of two states (1 or 0) and remember it until changed. Somewhat like a one-bit memory device.
- Full Adder - A circuit for adding two binary numbers and a carry bit (so three bits overall). It will produce a sum and a carry.
- FPGA - Field Programmable Gate Array.
- Half Adder - A circuit for adding two binary numbers. It will produce a sum and a carry
- Inverter - See NOT Gate.
- IP - Intellectual Property. Typically a third party module that does a particular function that you can integrate into your FPGA designs if you wish.
- Logic Diagram - See Schematic.
- Non-blocking Assignment - In Verilog, when an assignment occurs in parallel with other assignments in the same block.
- NOT Gate - A gate that takes a single input and inverts it. That is, a 1 becomes a 0 and a 0 becomes a 1.
- OR Gate - A gate who's output is a 1 if any inputs are 1.
- Schematic - A diagram of a logic circuit made up, usually, of logic symbols for fundamental gates.
- Sequential Logic - Logic that typically uses flip flops and the current output state influences future output states.
- Testbench - Verilog (or similar) code that exists only to send stimulus to a simulated device and record or test the results.
- Truth Table - A table showing a logic circuit's possible inputs and the outputs that will result.
- Workflow - The process of taking design inputs and producing a working FPGA configuration.
- Verilog - A description language used to describe logic you wish to place on an FPGA.
- VHDL - A description language (not used in this bootcamp) to describe logic you wish to place on an FPGA.
- XOR Gate - Exclusive OR gate. A two-input gate that sets its output to 1 if either input is a 1, but not when both inputs are a 1.
Logic Truth Tables for Two-Input Gates
A B AND OR XOR 0 0 0 0 0 0 1 0 1 1 1 0 0 1 1 1 1 1 1 0 -
How People Use FPGAs
06/24/2018 at 19:54 • 0 commentsThere are a few ways people tend to use FPGAs:
1) Replace logic gates like AND and OR gates, flip flops, etc.
2) Perform algorithms in hardware which can be very parallel either with or without a CPU
3) Provide custom I/O devices for a CPU
4) Build custom CPUs
You might think that these are all just applications of #1 and to some extent you'd be right. However, in many cases people use "Intellectual Property" or IP to build up algorithms, custom CPUs, or custom I/O devices without actually worrying about the details. Just like you can use someone's C library in your Visual Basic Program even if you don't need C, IP lets designers share functions with people who might not be able to build them themselves. We won't talk much about that because we want to design!
Another trend is to see FPGAs married with CPUs either on the same board or, in some cases, in the same package. Sometimes, the FPGA has an actual CPU hardwired into the silicon. In other cases, the CPU is "soft" and just consumes some of the resources available to you as an FPGA designer.
A lot of example FPGA projects don't really show the best uses of FPGAs. For example, a fair beginner project might be a simple traffic light with some red, green, and yellow LEDs. But the reality is there is no advantage to using an FPGA for this over a processor. The time scale is relatively long and doesn't need high precision. FPGAs are harder to work with and often take more power than a stand-alone CPU. So you really want to use them where there is a compelling advantage.
For example, suppose you have an industrial process that if any limit switch hits you need to stop immediately. Further, for whatever reason, every switch needs to be separate. So if you have 10 switches you are going to have 10 inputs.
On a CPU, the simple way to do it would be to test each switch in turn. But that's going to be slow because you have to look at switch 1, then switch 2, and so on. Presumably, the CPU is also doing something else.
Another idea would be to get all 10 inputs into a 16-bit word, for example, and test that. That's better, but still doesn't solve the problem of you have to do other things and while you are doing those things, you aren't watching the switches. You'd probably want to make each switch generate an interrupt (or OR them together and use that as an interrupt). That's better, but there are still times when an interrupt won't occur right away, so the timing won't be great.
Now what if you have 50 inputs? Your timing is probably going to be worse. With an FPGA, you could make each input trigger circuitry and while it won't be instant, it won't matter significantly if you have 10 or 50 inputs. At some point you'll run out of pins, but until then, it won't matter.
In effect, all the switches "run" in parallel. This is useful for processing audio or video, too. Say you have audio buffered at 22 kHz for one second. That's 22,000 samples. You need to do some math operation. A common CPU will do one at a time. If you have threads, you might be able to pretend to do more. Some CPUs have special instructions made to do things in parallel, but maybe not 22,000 at once. With an FPGA of the right size, you could define the math block for one sample, duplicate it 22,000 times and -- with the right memory architecture -- do the processing in what amounts to a blink of time.
So for learning, it doesn't really matter. But in the real world, you want to pick the right tool for the job. FPGAs aren't for everything. But when you need their inherent parallelism, they can be the best -- and most practical -- choice.
Verilog?
06/22/2018 at 21:52 • 0 commentsVerilog is one way to do design entry -- the process of telling the FPGA tools what you want the FPGA to do. Just like software might be in C or Python or Java, there are many ways to do design entry. It is often possible to use schematics -- really logic diagrams -- to define an FPGA, but there's good reasons why that doesn't work as well on larger projects that we will talk about in this bootcamp.
However, you will many people use VHDL which is very similar in concept to Verilog. However, where Verilog is somewhat similar to C, VHDL is very similar to Ada. There are other options, as well. There are tools that will convert limited subsets of the C language to FPGA configurations, for example. There's also System Verilog which has a lot of additional features, most of which are aimed at simulation.
There are also lesser-used languages. Some are proprietary and have mostly fallen out of use. Some are newcomers that usually look somewhat like another programming language. SpinalHDL and MyHDL are examples. The purpose of all of these things are the same: to inform the FPGA configuration tool what it is you want.
Obviously, not all tools are going to take all languages. However, if a toolset can handle, for example, Verilog and VHDL, you can probably mix these if you want in one project. That may seem crazy, but it is a great benefit if you have libraries or functions from a third party in one language and you want to use another one.
This is usually possible because there is a fairly standard intermediate format called EDIF. If you buy IP (intellectual property) from a vendor, it will probably come as an EDIF file. That means you won't be able to easily edit it, but you can add into your designs.
The tools we are going to use with the IceStick just do Verilog. But if you use commercial tools, you'll likely have an easy time using at least VHDL or Verilog, if you choose. However, this series of bootcamps is going to focus on Verilog.
FPGA Timing
06/22/2018 at 06:12 • 0 commentsWe will have a lot more to talk about for timing in future bootcamps. But I wanted you to think about the speed things operate at. FPGAs usually have a speed rating and the tools have great models of how long a signal will take to propagate from point A to point B at a certain temperature.
For simple combinatorial logic like we have in this bootcamp, it won't matter much. The delay through the gates are going to be VERY short (like picosecond-range). However, complex circuits can have issues. Consider a case where a gate takes two inputs. A change on the FPGAs inputs goes through some logic and hits our target gate in 150pS. The other input sees the same outside input change but takes 200pS to do its work.
That means for 50pS the output could be wrong. For example, suppose the circuit were perfect. Because the two inputs of the AND gate are inverse of each other, the output must always be a zero. However, if the input were high for a long time and then switched to low, the top input to the and gate would change in 150pS. The bottom input is still high for another 50pS before the change registers. During that time, the AND gate could put out a high. The truth is, it won't change state instantly, so it may not go high for the entire 50pS.
This is sometimes known as a glitch. The more gates between point A and point B, in general, the longer it is going to take. Sometimes, too, a long routing path will cause a longer delay. You may think this is a dumb example because the output shouldn't be able to change. That's true but I wanted to make a point. Besides, you often see this exact circuit used to detect an edge which takes advantage of the glitch. However, you should NOT try to implement something like this in an FPGA. Instead, just think of the buffers as representing some number of arbitrary gates for the purposes of this example. Exactly what it doesn't isn't important.
We will learn a way around this problem in the next bootcamp (with sequential logic). However, that will cause timing problems of its own and we will have to learn how to work through those as well.
FPGA Workflow
06/21/2018 at 23:00 • 0 commentsExactly how you "program" the actual FPGA hardware depends on which chip and vendor you are using. In the bootcamp where we actually program the IceStick, you'll see more details about exactly how to do it. However, most FPGA "builds" follow a very similar flow and you might find it interesting to know what that is.
If you think about a conventional C program, your workflow looks like this:- Compile C code to object code
- Link object code and libraries to executable
- Debug executable using simulation
- Prepare executable for downloading
- Send executable to target system
- Debug executable on target system
The details vary, but a generic FPGA workflow looks like this:
- Synthesize Verilog into low-level constructs
- Simulate/test/debug system behavior
- Map low-level constructs to specific device blocks
- Place and route blocks -- this means to plan which blocks go where and exactly how to interconnect them
- High-fidelity simulate/test/debug on actual device-specific configuration
- Program configuration to FPGA or configuration device
- In circuit test/debug, if necessary
Some vendors use different terms for things like blocks or place and route, but the ideas are universal.
You might wonder why you would test and debug at three different stages. The simulation in step 2 is like we are doing in this bootcamp. You deal with the source code, things work pretty fast, and you can catch logic errors in your design.
What you can't catch is problems caused by how things are set up on the chip. Maybe this signal arrives just a little too late and causes an error. The device-specific simulation in step 5 can catch that. But it is generally a lot more data to process and model so the simulations take more time and memory. On a big design it can also be costly to have to go fix source code and then re synthesize. So you try to catch your logic errors in the second step.
Of course, nothing works exactly like it does in simulation so sometimes you have to debug on the chip. Modern chips have tools to help you see inside them just like modern CPUs have on chip debugging support. But it is still harder and more time consuming.
Thoughts on FPGAs
06/21/2018 at 22:50 • 0 commentsWhen you were a kid, did you ever see one of those 100-in-1 electronic kits? These were a board with a bunch of parts on them and some kind of solderless terminal. If you hooked wires up one way it was a car alarm. If you hooked it up another way it was a metal detector. A third way made an AM radio.
That's a lot like what an FPGA is. There are a bunch of blocks of functions waiting for you to wire them up. Usually, most of the blocks are exactly the same and there will just be a few special blocks, although some FPGAs will have a significant number of different block types. Exactly what each of these blocks do depends on the FPGA but luckily the tools shield us from most of this complexity. For example, there might be a block that is a look up table (LUT) that holds a truth table that converts, say, 4 inputs to 1 output. That LUT might be grouped together with a flip flop or two and some programmable inverters. Other blocks might provide RAM memory, DSP functions, or clock generation circuits. But almost always the tools will take your Verilog and figure out how to wire up the blocks to build your circuit. As an example, here's a typical FPGA cell:
The LUTs are look up tables with 3 inputs. The FA is a full binary adder (just like the one we are using in this bootcamp, except it takes a carry in as well as an A and B input). The muxes are electronic switches. The output can be either of the two inputs based on either an input (like d for the leftmost mux) or by configuration for the other two muxes. The block marked DFF is a flip flop and we'll talk about those more in a future bootcamp.
So if you had this cell and our Verilog from this bootcamp, the tool would probably route a and b to our A and B inputs. It should be smart enough to make the LUTs just forward those bits to the full adder. The output of the full adder would route through both muxes to the output. And the carry out would be routed to our other output.
It is interesting that fundamentally an FPGA is a memory device. Instead of storing numbers, though, it stores "wires" continuing the kit analogy. Some of those wires select options (like use inverted X as the first input) and some wires connect inputs to outputs. Some FPGAs are based on RAM and need to be loaded every time they power up. That load could come from a CPU or a dedicated memory chip (usually a serial EEPROM). Some devices have a configuration EEPROM onboard. You can probably load the device from a PC using the development tools, also. But if you do, remember the next power cycle won't bring back your "code" -- you'll have to program the EEPROM device for that. Looking at the figure above, each LUT has 8 bits (3 input bits can take a value from 0 to 7). The two muxes furthest to the right are configured so that's one bit each. In addition, there will be bits to select where all the pins entering or leaving the block actually go. This can vary depending on the actual FPGA, but in general all the logic can be placed on one of many local or global busses. The clock signal (clk) probably has its own busses that is separate.
Other FPGAs are based on nonvolatile memory cells. You can program these and they stick. That's handy at development time, but there is some limit to how many times you can program them, just like flash memory. That limit is pretty high though. One advantage to the FPGAs that stay programmed is they are general ready to operate immediately when the circuit powers on. If the FPGA has to read a configuration from a host computer or a EEPROM it is going to take some time and usually the I/O pins are idle during that time. You have to take care to design around this and also your design has to be able to tolerate that reset time on every power cycle (or even a reset, typically).
It is an advanced technique, but it is possible to reprogram only parts of the FPGA on the fly. For example, a system with a CPU could use an FPGA to provide many PWM outputs and DSP algorithm. However, it could also reprogram the device to replace the DSP algorithm with another without disturbing the rest of the chip. This is difficult to get working and exactly how it works -- or if it is even possible -- depends on the FPGA you are using.
Al Williams
