32marlin board
- ARM 32-bit Cortex™-M3 CPU STM32F103VCT6 72 MHz maximum frequency
- Auto controlled Fan on big cooling fins shell,prevent fan from pulling in dust to motherboard directly
- with board monitor temperature sensor, software can control the Fan automatically and avoid stepper reboot while over temperature or stop print while fire on board.
- silent fans, support fans of 5V/12V/24V, as we know that 5V fans is silent than 12V/24V.
- Support 2 extruders.
- Highly current, support 400w big hotbed.
- small mosfets (40V 200A ) for one large heat bed, High performance and no heat generated so no need external cool sink or fan.
- 2 (40V 100A) small mosfets for 2 hotends. High performance and no heat generated so no need external cool sink or fan.
- Integrate power off detector with super capacitance.
- Highly integrated, small size.
- MicroUSB interface
- MicroSD card slot
- Built in 5 UART controlled silent stepper drivers TMC2208 ( peak current 2A, voltage range 4.75V-36V, 256 subdivision).
- Digital current control ( no need to use a screwdriver to set a potentiometer for current setting )
- 12 to 24V power input
- Extension:UART,STLink
- 3 thermistor input (12 bit ADC) for thermistors
- 3 endstop inputs
- auto bed level port,BLTOUCH and inductive probe
- Open source hardware,community developped
32marlin software
- Firmware is developped base on the Marlin1.1.9,almost all the code is the same.
- Supports all features found in Marlin firmwares which is used on over 90% of printers worldwide.
- High step rate(50Khz now) for higher movement speed or high microstepping.
- Use the easiest IDE tool that we developped for Marlin STM32 instead of arduino IDE.
- Open-Source Software ( GPL v3 ), community-developped
robert
Pontus Borg
Chris Slothouber
J.R. Stoner
derethor
Not 1 single reply from the creator. I can only assume this project was dead before it got started...
