Inspired by both Robotis Darwin Mini and Dr. Guero, I'm on a quest to build a dynamic gait bipedal walker that would walk like you an I.
I have started to tinker with ROS and Gazebo to implement what will be the most crucial part of the robot: Its brain!
Finally, the bottom part of my biped named Walk-R is now done. After countless redesign and re-prints, here it goes!
I will now spend my time researching how best to make it alive.
The next steps:
That's it!
Stay tuned!
I finally got sick of battling with the XL-320, OpenCM and Pixl boards. It was either not working under Linux or not working with more than 6 servos.
So, I looked up for something else and after a while, my choice stopped on the LewanSoul servos. So far, they meet my expectations. I have 1 leg done (minus the foot, which requires a redesign) and I'm waiting for the next batch of servos to come at my door.
Stay tuned, as I will show up where I'm at when the second leg (and hips) is done!
I've begun to port the thing from the OpenCM to the Raspberry Pi, using the Pixl board.
I still have issues with it, though. Next post should be when I have solved those issues and have a robot standing on its own two legs!
Next goal: A self-balancing biped bot...
This looks great! Almost gave up on the legs for my own humanoid robot that is very similar to this design, thank you for sharing!
Thx!
