Macbook Pro RAM upgrade
Soldering in 16GB of RAM. Easy or buy a new Mac after the attempt? ;)
Public Chat
Note: i stopped this project and sold the macbook. This has not been attempted and should only be read as entertainment and inspiration. Please research yourself!
Please note that everything below is theoretical at this point, do NOT desolder your RAM just yet ;)I'm still in love with my by now classic Macbook Pro early 2015 13". It's a wonderful little Macbook but two specs are becoming a bit... outdated and that is the disk-size and the amount of RAM. Mine came with 8 gigabytes worth of RAM (max was 16GB and that was way too expensive back then). A random google showed that it is actually possible to upgrade soldered RAM chips on some Macbooks, so now i'm investigating mine. My inspiration was this video on Youtube:https://www.youtube.com/watch?v=CTsEJ49LLsQNote: this projectblog uses some photos (or crops thereof) from iFixit.com from their Macbook Teardown, which is a great read in it's own right.
My Macbook is a A1502, 820-4924 board.
In the schematics we're off to a promising start
So all different models of this macbook are done with the same logic board. And apparently all models use 1866mhz DDR3, either by Hynix, Epida or Samsung
And you can configure the amount of RAM using some config-lines!
So this seems to be pretty straightforward. The different options of RAM are controlled by a few GPIO lines on the CPU which are either pulled high or low with a few resistors.
Now what model of RAM should we buy? Apple provides one type in the schematic:
LPDDR3-1600-32GB, EDFB232A1MA
Which leads to... A testing document by Intel in which they've tested compatibility of various RAM chips for the specific CPU i'm using:
So i'll probably need either:
  • Micron EDFB232A1MA-JD-F
  • Samsung K4EBE304EB-EGCF
  • Hynix H9CCNNNCLTMLAR-NUD
And with a bit of puzzling i've figured out (i think) what each of the 4 configuration settings does:
My questions now: is my reasoning correct in assuming the three chips i've mentioned will probably fit and work? Where can i obtain these chips?
SKhynix2015_New_part_decoder_LPDDR3_201510.pdf
Part number decoder LPDDR3
Adobe Portable Document Format - 59.48 kB - 03/07/2019 at 17:10
Preview
lpddr3-1600-5th-gen-core-ult-validation-results.pdf
Intel LPDDR3 validation results for the 5th gen core ULT chips.
Adobe Portable Document Format - 242.63 kB - 03/04/2019 at 20:18
Preview
Schematic 820-4924_a_a1502.pdf
Schematic for the Macbook Pro 13" 2015
Adobe Portable Document Format - 1.40 MB - 03/04/2019 at 20:13
Preview
820-4924-A.brd
Boardview for the Macbook Pro 13" 2015
brd - 575.54 kB - 03/04/2019 at 20:13
Download
  • 4 × H9CCNNNCLTMLAR-NUD 4 gigabyte RAM chips, LPDDR3, 1866mhz
  • 1 × Macbook Pro 13", 2015 Base model, 8GB
  • Planning the soldering
    Sebastius03/08/2019 at 21:08 0 comments
    Besides soldering the RAM itself is that a few config lines need to change (based on the schematic and my RAM, both Hynix brand 1866mhz):
    RAMCFG0 H -> L
    RAMCFG1 L -> H
    That means the following resistors need to change
    R1611 moves to R1635 (100k)
    R2052 moves to R2053 (10k)
    The components can be located using the .BRD file and the utility Openboardview.org
    moves to
    And then
    moves to
    So this issue is mainly finding the right resistors and pads.
  • RAM is in!
    Sebastius03/08/2019 at 15:58 0 comments
    In a very fast DHL maneuver, the RAM is in. Note: i will not be soldering these chips any time soon, i'll first want to practice a LOT on old SO-DIMM modules.
  • Scraping
    Sebastius03/06/2019 at 21:59 0 comments
    Well i have a shipping notice on the RAM, but i still need to confirm everything might work. My chip has two different letters in it's code compared to the original Macbook RAM as shown by iFixit.
    The SK Hynix site does have some documentation on some of their chips and how it is labeled. It is however incomplete: the document for LPDDR3 is missing. I suspect it might still be in their archive, just not on the website anymore. So i've asked a friend of mine to write a little scraper:
    for i in {0..1000}; do wget --content-disposition --no-clobber "https://www.skhynix.com/static/filedata/fileDownload.do?seq=$i"; sleep .5; done
    Which downloaded SK Hynix entire archive for me in a few minutes. Besides their annual reports, catalogues and some other stuff i hit the jackpot: the LPDDR3 naming scheme!
    So my chip is the H9CCNNNCLTMLAR-NUD and that translates to:
    H - Hynix chip!
    9 - MCP product family
    CC - MCP DDR3 only
    NN - None NVM density
    N - None NVM Voltage
    CL - I assume 32Gb, QDP, 1Ch, 2CS (but not confirmed), 8GB is the BL
    T - 1.2V/1.2, x32
    M - 1st Die generation (iFixit is 2nd)
    LA - FPGA 178 Ball
    R - Lead & Halogen free
    N - None NVM speed
    U - DDR3 1866 (CL14)
    D - Not sure yet, but related to operating temperature
    So it seems my memory might be compatible for my plans!
  • Confirming some suspicions
    Sebastius03/05/2019 at 22:47 1 comment
    Today i did some digging. Turns out the 'About my mac' menu can tell you the RAM manufacturer.
    The manufacturer code 0x80AD translates to SK Hynix, which is fortunate because it matches the brand i've ordered my chips from. For your record, a partial list:
    • 0x014F - Transcend Information
    • 0x2C00—Micron Technology, Inc.
    • 0x802C—Micron Technology, Inc.
    • 0x80AD—Hynix Semiconductor Inc.
    • 0x80CE—Samsung Electronics, Inc.
    • 0xAD00—Hynix Semiconductor Inc.
    • 0xCE00—Samsung Electronics, Inc.
    Further digging on the ifixit.com website turns up their 8GB model also has Hynix memory and thanks to their awesome board-photo's i can determine the model RAM on their board (i will need to open my Macbook at some point still to confirm).
    It's the H9CCNNNBLTALAR-NUD chip. The ones i ordered are hopefully of the same series, the H9CCNNNCLTMLAR-NUD version. There are two letters different, of which i think i've determined that the B-C stands for the 16->32gigabit upgrade and the A->M stands for the A revision->M revision.
    The nasty is that i'm unable to predict a working system because all my variables are unknown:
    • Are the chips i buy really brand new and 100% okay
    • Will my soldering be good enough
    • Will adjusting the jumpers work
    • Is there magic in the firmware of the macbooks that is (in)compatible with these chips
    • And probably other stuff i'm forgetting...
  • RAM ordered!
    Sebastius03/04/2019 at 20:12 1 comment
    In a blatant leap of faith i've ordered some RAM chips on Alibaba: 4x the H9CCNNNCLTMLAR-NUD made by Hynix. It lists as compatible on the Intel documents, and had the capacity and speed i need (4x 4GB or 4x 32Gbit). Shipping is done by DHL so it should be here soon. Now i need to work on my nerves as i will have to take apart my beloved little Macbook...
View all 5 project logs
Rich text editor
gediminasius wrote 01/06/2023 at 20:46 point
Hello, anyone upgraded successfully? Maybe someone have spare LPDDR3 2GB left after upgrade? I can buy them on the cheap for my old tablet upgrade.
Chris wrote 11/28/2021 at 20:22 point
how did you determine all of the "strap" / resistor configurations for your board?
• how did you determine which resistor values need to be what, depending on the memory installed?
terentev wrote 06/25/2020 at 21:10 point
can i Macbook 12 Early 2016 upgrade to 16GB?
can i Macbook 12 Mid-2017 16GB upgrade to 32GB?
jefernandez.frutos wrote 06/12/2020 at 22:10 point
anybody has try to upgrade to 32 GB ? did it work ? Which chip did you buy?
Dmitriy Sergeev wrote 10/27/2020 at 15:06 point
First you need to check if such configuration exists, because if it's not you won't be able to upgrade to 32GB without BIOS fix. Which is close to impossible I guess...
LuisEduLeiva wrote 06/06/2020 at 02:02 point
Can I upgrade i5 2.7ghz 8gb Ram Macbook Pro early 2015 a1502 to i7 3.1ghz 16gb Ram buying a logic board?, should it work?
Dmitriy Sergeev wrote 10/27/2020 at 15:03 point
I think it should. I was going to do it myself in case of things went wrong. But luckily I escaped the necessity of changing motherboard. In worst case you'll have to find out yourself.
Dmitriy Sergeev wrote 02/28/2020 at 22:18 point
I've done it, guys. I did everything like the project author described, including memory configuration change made by strap resistors. I bought the same memory chips on Aliexpress, they cost me about $65 per set of 4 Hynix chips. The only thing I would add - it's really hard to replace memory chips at home using just hot air soldering station like that Chinese guy on the video did. So I brought my motherboard to a service since they had professional infrared soldering station. Well, I paid some extra, but got the result in the end =)
So, I can confirm it's possible and everything that Sebastius has written was correct (like)
mseidenfaden wrote 04/12/2020 at 04:39 point
Were there any other modifications you had to make besides replacing the Ram chips and changing the resistor configuration like for example modifying the bios?
Dmitriy Sergeev wrote 04/14/2020 at 07:46 point
No, I did nothing in addition, just replaced RAM and changed resistors. I think the bios already contains all possible configurations of RAM and is ready for the changes. Besides, I guess you can also upgrade the CPU replacing it for i7, since motherboards with this configuration are also could be found. But this upgrade wasn't in my plans, so it's just my assumption. I'm pretty satisfied with twice bigger size of RAM, it really helped to speed up my work )
alfredytl wrote 05/06/2020 at 13:12 point
Hi Dmitriy may i know where u order those ram part? could u share the link to buy those?
Dmitriy Sergeev wrote 06/09/2020 at 21:48 point
Sure... I've ordered ram on Aliexpress from this seller:
https://aliexpress.ru/item/4000072173721.html
The only feedback there is mine, and btw you can see screenshots with the system info before and after replacement. The delivery was to Russia, but as far as i know they deliver worldwide as well. Good luck! )
terentev wrote 06/25/2020 at 21:15 point
you changed resistors on motherboard?
Dmitriy Sergeev wrote 10/27/2020 at 14:56 point
Yes, just like it was mentioned above in the upgrade description.
zander wrote 01/02/2020 at 16:49 point
How is your result?
Justin Morrison wrote 12/12/2019 at 04:02 point
I'm also following this and last I saw you ordered the ram. Hows the desolder practice going?
Josh Richardson wrote 10/19/2019 at 18:45 point
I'd also be very interested to know if this worked. Thinking of doing the same thing.
gary schechter wrote 10/17/2019 at 04:39 point
Did you ever get any further on this?
