My Macbook is a A1502, 820-4924 board.
In the schematics we're off to a promising start
![](https://cdn.hackaday.io/images/5101111551644924995.png)
So all different models of this macbook are done with the same logic board. And apparently all models use 1866mhz DDR3, either by Hynix, Epida or Samsung
![](https://cdn.hackaday.io/images/6475821551644956165.png)
And you can configure the amount of RAM using some config-lines!
![](https://cdn.hackaday.io/images/3421921551644972983.png)
![](https://cdn.hackaday.io/images/8956231551644980714.png)
So this seems to be pretty straightforward. The different options of RAM are controlled by a few GPIO lines on the CPU which are either pulled high or low with a few resistors.
Now what model of RAM should we buy? Apple provides one type in the schematic:
![](https://cdn.hackaday.io/images/2715051551645003310.png)
LPDDR3-1600-32GB, EDFB232A1MA
Which leads to... A testing document by Intel in which they've tested compatibility of various RAM chips for the specific CPU i'm using:
![](https://cdn.hackaday.io/images/1185081551645013332.png)
So i'll probably need either:
- Micron EDFB232A1MA-JD-F
- Samsung K4EBE304EB-EGCF
- Hynix H9CCNNNCLTMLAR-NUD
And with a bit of puzzling i've figured out (i think) what each of the 4 configuration settings does:
![](https://cdn.hackaday.io/images/2579641551645044814.png)
My questions now: is my reasoning correct in assuming the three chips i've mentioned will probably fit and work? Where can i obtain these chips?
Hello, anyone upgraded successfully? Maybe someone have spare LPDDR3 2GB left after upgrade? I can buy them on the cheap for my old tablet upgrade.
