21Step 21
Slot both sides on o the grip, pushing the top into the slots like shown:
and then slotting them in so they are flat against the side:
22Step 22
Now slot the grip on to the servo and hold the second one loosely in place:
23Step 23
And finally slide the base in to place which will hold everything together and put a 10mm screw through the second grip
The put an elastic band around it as shown to keep it all tight:
The grip is now complete so we'll join the three parts we've made together
24Step 24
Attach the grip to the main arm as shown:
25Step 25
And then slot the servo horn on the base between the two sheets of perspex
and make sure the servo horn locks into place:
And then hook an elastic band over the end to hold it in place and act as a foot
26Step 26
Plug the base in to the arm with a 6 pin cable:
27Step 27
That's the physical part of the assembly done! Not too shabby!
28Step 28
To get the whole thing working you need to install Node.js and get the software which runs it all. Here are the steps:
1. Install Raspbian
2. Install Node.jsRun the following commands from the terminal on your Raspberry Pi
sudo apt-get remove nodered nodejs nodejs-legacy npm -y sudo curl -sL https://deb.nodesource.com/setup_7.x | sudo bash - sudo apt-get install -y nodejs
Then when you type "node -v" it should print out the version you installed
3. Install pigpio
wget abyz.co.uk/rpi/pigpio/pigpio.zip unzip pigpio.zip cd PIGPIO make sudo make install cd ..
4. Install git
sudo apt-get install -y git
5. Install the Mearm program
- Clone the mearm-js repository
git clone https://github.com/mimeindustries/mearm-js
- cd into the repository
cd mearm-js
- Install libraries and run the program
npm install sudo node server.js
The arm should spring into life and the Joysticks should control it
29Step 29
And here's the arm I just built working:
