Uses Raspberry Pi DPI operating with 32MHz pixel clock. (32MHz is the clock limit of the XMega)
- Provides consistent panel timing regardless of CPU load.
- Capable of drive large arrays with high refresh rate.
- Software driver derives array dimensions from Linux framebuffer device, pwm bits, and panel type.
- Panel CLK is produced by simple AND gate using pixel clock and DEN signal.
An Atmel XMega uses the pixel clock as it's external clock for synchronization.
- Use HSYNC edge to capture scan line data from first few bytes of each scan line.
- Generates PWM signal
- Outputs row select bits
- Generates LAT signal
Current Panel Configuration:
- 48 Qiangli Q3F32 v4.1 panels (64 x 64, not hub75 compliant)
- Canvas size: 768x256
- Refresh Rate: 82Hz
- Max OE active time: 49% at full brightness
Nick Sayer
Julien
ElecLab
Hi
Please help me to add slowdown gpio setting for my panels
