Precision ventilator
This project contains modular components for a ventilator. The design is in a South African context.
Public Chat
There are many DIY ventilator projects which do not consider the complex sensing requirements of a real ventilator. This project aims to provide flow sensing, pressure sensing as well as pressure and flow control devices/methods.
 Specifications and Constraints
Pressure sensing accuracy must be within +-1cm H2O.
Volume flow rate accuracy must be within +- 25ml/min.
The cyclic rate of the tidal volume must be controllable to within +- 0.5 bpm. The rate must be configurable between 10 – 30 bpm.
Pressure sensor
Critical components of ventilators are the pressure sensors. Good pressure sensors are needed to keep the pressure within the bounds stipulated in the specification provided.
Table 1: Comparison of applicable sensors
BMP280
BMP388
XGZP6847
Precision
0.00163 cm H2O
0.00163 cm H2O
Determined by MCU ADC Resolution
Accuracy
1.019 cm H2O
0.51 cm H2O
1.019 cm H2O
Sampling Rate
157 Hz
200 Hz
Determined by MCU Clock Speed
Cost
R60
R60
R180
The XGZP6847 is a differential pressure sensor which would compensate for external pressure fluctuations. An important consideration if the device is to be used in Cape Town (101KPa) as well as in Pretoria (86KPa). Another important note about the above devices is that the actual pressure sensor on the breakout board of the BMP280 and BMP388 costs about the same.
Availability of sensors will be the deciding factor between the XGZP6847 and the BMP280 as their performance meets the specifications.
Venturi - flow sensor
Air flow rate sensors are generally in excess of a few thousand rand. Alternatives such as a venturi could be used to keep costs low. With the use of a 3D printed venturi nozzle, repeatable characteristics will potentially be achievable. Tuning the relationship between pressure and flow can be done with a well documented flow meter.
The upstream flow sensor design is in the figure to the left. It just measures the static pressure of the air at some upstream location to the venturi.
The Sensor is a bmp280 module. Future designs will use a custom pcb for cost reduction.
The venturi is pictured in the image on the left. The sharp taper, 20 degrees, is the inlet and the 7 degree taper is the outlet.
The venturi has not be tested. The lock-down in SA is limiting access to proper equipment.
Hot air anemometer - flow sensor
A hot air anemometer measures the rate of heat loss from an element by measuring the elements resistance in some way. The prototype shows promising results but actual performance of the device has not been measured.
Blowing on the element lightly produces a smooth waveform. Hopefully in the coming week it will be tested and proper specs will be given - accuracy/repeatability between sensors.
Flow/pressure control
Altering the duty cycle of solenoids rapidly switching could potentially be a cheap method of producing pressure/flow wave forms from a higher pressure buffer. This method is being investigated and progress will be uploaded.
Using servos mounted on ball valves is another option for flow/pressure control.
These two methods can both work potentially but, again, availability will be the deciding factor. Ideally both methods should be developed to a usable device.
UV filter for killing pathogens (not viable - more expensive that HEPA filters)
Although the wavelength of these UV LED's are not ideal. They are still UVC and thus can potentially be used to clean the ventilator exhaust air.  The benefits of this method over filters is the reduction of consumables and the reliance on suppliers.
Critical factors for sterilization using UVC include LED irradiance, exposure time and fluid velocity.
The initial idea for this is a cylinder with a slanted input to induce an air vortex inside so that the same air does multiple passes over the UV LED's. This concept will be investigated at a later stage.
Solvent based air filter
The air leaving the patient can be bubbled through a liquid using a fish tank aerator. The liquid will be a strong solvent that breaks down the viruses outer shell. The viability of this has not been investigated.
Water purification fluorescent lights for filtering air
Fluorescent lights for water purification are a magnitude cheaper per watt in comparison to...
  • Lock down update
    Simon Harvey • 04/08/2020 at 06:00 • 0 comments
    With South Africa in lock down. We are not able to buy the right pressure sensors to work with the low pressures.
    Instead Research is being done on UV sterilization. The exposure time needed as well as the distance from the air. The Sterilization tank will probably need to be a distributed component to keep costs low. The air velocity through a 20mm diameter pipe will be between 0.31 m/s and 0.03m/s for the specifications given and will probably be closer to the slower for the majority of the ventilating.
    While we can't leave our houses there's still some programming to be done. Will try use smartphones to plot the pressure, flow and volume waveform into the lungs.
  • Closed loop pressure control.
    Simon Harvey • 04/07/2020 at 10:52 • 0 comments
    Currently in the process of implementing pressure control by changing the duty cycle of these solenoids to maintain a specific pressure.  Once this is achieved wave-forms of pressure, hopefully, can be generated by altering the duty cycle.
    Ball valves with servos attached are another alternative to the solenoids but have increased costs.
View all 2 project logs
yeveya4790 wrote 07/15/2024 at 10:37 • point
A precision ventilator is a medical device designed to provide accurate and controlled respiratory support to patients. It ensures precise delivery of oxygen and airflow, tailored to the patient's specific needs. These ventilators are crucial in critical  https://practicewithease.com/  care settings, providing life-saving support for patients with severe respiratory conditions. Advanced sensors and feedback systems allow for real-time adjustments, enhancing patient safety and treatment effectiveness.
joe.jasniewski wrote 04/21/2020 at 17:44 • point
I watched "The boy who harnessed the wind" and his trip to the dump reminded me so much of myself -when I was his age and even today  Even in America with its abundance of people's junk lying about, it's still hard to locate a precise thing that you need - like a solenoid actuated, wide pipe diameter valve.  Thinking https://www.ebay.com/itm/3-4-24V-AC-Solenoid-Valve-Plastic-Potable-Drinking-Water-Air-Electric-NPT-N21E/122750490691  Do they ship to Africa?
joe.jasniewski wrote 04/08/2020 at 16:05 • point
Use a resistor-heated thermistor placed in the airflow as a mass flow sensor instead of the venturi? The solenoid valve is quite small the force breath volume through.  Try a DC water valve intended for home irrigation (sprinkler) system  - it may convey larger air volume more quickly, due to larger ports / valve geometry.
Simon Harvey wrote 04/21/2020 at 12:21 • point
Thanks for the tips. The small valve was all I had here and I cannot currently purchase anything else.
I suspect a ball valve is going to be the easiest to implement so might start with that once the lockdown is lifted.
