Manual knob
10/04/2020 at 23:27 • 0 comments -
the feder system
10/04/2020 at 23:25 • 0 comments -
Some more photo's
10/04/2020 at 23:23 • 0 comments -
Some photo's
10/04/2020 at 23:22 • 0 comments -
Website online
10/04/2020 at 23:07 • 0 commentsWebsite online
www.uni-flex.be -
Nextion screen stable running communication
06/01/2020 at 04:00 • 0 comments#define NXTSerial Serial2 // Serial port to connect with Nextion panel
Set serial port to use with the arduino board
void NxtOpenSerial() { //This is for serial Nextion display. NXTSerial.begin(19200); }
To open the serial communication with the HMI display.
void InitNxtData(String dev, String data) { memset(NxtMsg, 0, sizeof NxtMsg); sprintf(NxtMsg, "%s=%s%c%c%c", dev.c_str(),data.c_str(),0xff,0xff,0xff); }
To add data to write something to the screen (first data)
void Add_NxtData(String dev, String data) { sprintf(NxtMsg, "%s%s=%s%c%c%c", NxtMsg,dev.c_str(),data.c_str(),0xff,0xff,0xff); }
Add next data as long as needed (to repeat).
void SendNxtData() { NXTSerial.print(NxtMsg); }
Send all the data.
To write to the HMI dispay, use it this way;void Nxt_Write() { InitNxtData("P1.val",NxtMessage); Add_NxtData("P2.val",NxtMessage); ... Add_NxtData("P3.val",NxtMessage); Add_NxtData("P4.val",NxtMessage); Add_NxtData("P5.val",NxtMessage); Add_NxtData("P6.val",NxtMessage); ... SendNxtData(); }
Example: Write 6 parameters to the Nextion screen.
repeat this routine on every 50ms and send only data when it changes to shorten your data transfer.
Because you send just one line of data it stays very responsive.if (old_P1!=P1) { sprintf(NxtMessage, "%u", P1); Add_NxtData("P1.val",NxtMessage); old_P1 = P1; }
This way you only add the data when there was a change in data.
On the other hand we wanted to read data from the nextion screen.void Nxt_Poll() { // READE DATA FROM PANEL delayMicroseconds(10); // 10 usec delay if (NXTSerial.available()) { byte inc; inc = (char)NXTSerial.read(); if ((inc >= 0xF0 && inc <= 0xFE) && !NxtSetStart) // <START MESSAGE> { NxtBufCnt = 0; NxtSetStart=true; } if(NxtSetStart) { NxtBuf[NxtBufCnt++] = inc; if (inc == 0x0A) // <END MESSAGE> { NxtSetStart=false; ...
Listen to the port if data is available, if so read char start message between (0xF0>0xFE)
If found read and store next character until character 0x0A has been read. This is the end of the message.
As you can see it is a very simple communication but it works very good.
Now lets check some data and do something with it.CheckNxtHex(0xF0,NXTparam); // Read parameter data from 0xF0 CheckNxtHex(0xF1,NXTstart); // Read parameter data fron 0xF1 and do something if (NXTstart==1 && !NXTstartFlag) {ee.active=!ee.active;NXTstartFlag=true;} // Toggle button (start/stop) if (NXTstart==0) {NXTstartFlag=false;}
and close communication
NxtBufCnt = 0; } } } else { // WRITE DATA TO PANEL Nxt_Write(); } }
I hope this explains a litle how I made a good and fast working communication with the nextion display.
From Arduino to Atmel Studio 7
05/29/2020 at 10:32 • 0 comments -
We needed to move controlled
05/24/2020 at 10:09 • 0 commentsWe take the cover of the box and made some things on it.
Every piece has been made to easily be removable. The motor Knob can be used when the machine is powered off to clamping the abu-bag between the two squeezers.
The spring system can be easily removed
Making of the mechanical strap system
05/24/2020 at 09:49 • 0 commentsTh
Here you see how it is brought into the enclosure.
It is very compact and fits perfectly!
It all started with a empty box
05/24/2020 at 09:10 • 0 commentsThis must make place for the electronics
The first 3D printed pieces where the front with its electronic components.
And this is the result
