I created L2Camera, because I had not found an Instax camera, that works for me. Later, I realized that with this project I can reduce the amount of photo-waste in two ways. Firstly, by re-using existing, but out-of-use photo equipment. Secondly, by giving photographers a tool that creates images of higher quality and leaves less discarded shots, which go to landfill.
To build your own L2Camera you'll need:
- find a donor Lubitel camera and a Kiipix/Printoss printer
- have a 3D printer and approx. 25 meters of PLA filament
- print the 3D model
- adjust the front panel to the viewfinder lens
- assemble the camera body
- align the lens
- assemble the whole camera
Prepare the tripod mount part - remove the brim if you printed with brims - then slide in the socket part into the hole at the bottom of the main body.
PengxiangXu
Richard Hogben
I just found out about this, have ordered a camera and print thing, downloaded the files and am now waiting on delivery.
