Integration
01/20/2021 at 22:20 • 0 commentsI have omitted the second CAN (RJ11) plug, since the RJ11 is bulky as it is and to save cable length. There is no need to run the CAN cable to a lamp twice if a splitter is more sensible. The Molex MicroFit 3.0 connector, for the external PWM fan, is not that tall, but it is reachable. Sometimes les is more.
Connectors
01/19/2021 at 21:01 • 0 commentsBy potting the connectors, when attached to the solder point cover, we can achieve a fully air and water tight "Opening". Since we already have to make a part for the solder point cover, we might as well use that as a opportunity for Human Machine Interface HMI through USB and CAN FD. Naturally the wireless module makes it straight forward to open a handheld iOs or Android interface. There are two PWM fan ports broken out through Molex Microfit 3.0 2x2 connectors. Some may prefer a fully wired system.
BREAKOUT
01/18/2021 at 23:04 • 0 commentsIn order to connect the lamp to a wired connection, a breakout is necessary. The USB power will cutoff if there is power on the 12v rail, to protect the computer motherboard.
The RJ11 CAN FD jack are compatible with DUET3.
The external FAN4 and FAN5 Micro Fit 3.0 connectors has 12v directly from PSU. The PWM signals are independently adjustable. A typical 120mm fan uses 0.5 amp at full power. The power connection for the external breakout is 9amp max.
The 4 pin header on the main shield is for wireless module UART (RX/TX) connection.
Temperature Probe
01/13/2021 at 22:54 • 0 commentsTo obtain the best possible control of the LED´s, we need to measure the temperature as close as possible to the LED heat pad. This will be done using a classic E3D thermistor in a cartridge (https://e3d-online.com/products/thermistor-cartridge). The sensor is 15mm long with a 50mm cable w. a good secure connector.
Dimensions
01/09/2021 at 14:24 • 0 commentsIn order to scale the wire connection to the MOSFET 40amp rating, Ive chose to fit 65 amp power lugs.
Heat exchange
01/07/2021 at 18:21 • 0 commentsHeating or cooling the heatsink is entirely dependent on current consumption and ambient temperature.
Looking at the heatsink, it is obvious, when pushing cool air across those fins, the air is gonna heat up. The above heatsink is for the small version 254mm long, 80mm wide, 40mm high.
Wire Shielding
01/04/2021 at 13:19 • 0 commentsThe LED phases must be soldered to the LED side, since the MCPCB is single sided. To shield of the solder points and wires, some sort of shield is is necessary.
Channeling
01/03/2021 at 14:29 • 0 commentsTo raise the light up into the enclosure, some sort of air channel is needed. This channel will also serve as mounting bracket for the wooden enclosure. On the LED side, the channel/bracket will provide mounting holes for wire shielding.
GROW AREA
01/03/2021 at 10:25 • 0 comments -
Xploring Enclosure V2
12/27/2020 at 10:41 • 0 comments
