Update wiring diagram
09/23/2022 at 11:37 • 0 commentsUpdate wiring diagram after finding a few errors when building some new units this month.
I won the Hackaday Earth Day Challenge 2021
06/11/2021 at 02:04 • 0 comments
Thanks Hackaday for awarding my project the winner of the Earth Day Challenge 2021 https://hackaday.io/contest/176995-earth-day-challenge -
Added meters per second readout
03/29/2021 at 11:27 • 0 commentsThe new calibrated version of the skit file is ready for download under V5 from our Gitlab.
We added meters per second to the display readout so now you can see both Kph and M/S. -
Calibration
03/27/2021 at 15:32 • 0 commentsCalibration with a commercially made flow meter:
In the image above we have the commercial flow meter on the left, a m/s to km/h conversion in the centre and the open flow meter on the right.
At first the open flow meter was providing a reading 4 times faster than the reading from the commercial unit, but after adjusting some settings both units give quite similar readings. Additional work needs to be done, however so far this will be more than good enough for GCSE, A Level and IB students usage. -
Battery Lid
12/29/2020 at 08:31 • 0 commentsThe battery lid now fits better and the new version has been uploaded to: https://www.thingiverse.com/thing:4700913 Make sure to print the new version as the old version did not fit!
24 hour submersion test
12/25/2020 at 04:53 • 0 commentsHere I leave the sensor in water for 24 hours to see if the silicon waterproofing of the electronics works.
When I switched on the control box and turned the prop, it still worked as before, so I'm happy enough with this waterproofing technique for now.
First complete unit
12/24/2020 at 15:03 • 0 commentsHere is the first fully assembled unit:
It features an: on/off switch, aviation connector, rechargeable battery, configurable intervals for taking speed tests and has a quick detach system from the ranging poll (this means we can carry less on field trips by using the range poll to hold the flow meter). -
Sensor testing
12/19/2020 at 03:50 • 0 commentsI tested a range of different pipe sensors at the start of this project back in April 2019:
I wanted to use the small clear sensor shown on the far right, however it could not measure slow moving water. The first sensor I built that was used for field work in a test was using the DN50 (the large black sensor, centre left of the image). But it still did not perform well in slow moving water.
The current build is now using the DN80, the one on the far left of the above image.
