More to come later on. Build in progress.
Follow me on twitter for frequently updates: r_frojd
Cheers
K3lso is a quadruped robot similar to MIT mini cheetah and MIT Cheetah 3.
Cheers
Weekend fun
Updated #k3lso to #Ubuntu 20.04 custom #PREEMPT_RT kernel on the #UPXtreme sniffing at around 7kHz per CAN channel (12 channels PEAK pcan FD) running ROS2
#quadruped #quad #ros2 #unitree #leggedrobotics #pcan #peak #robotics #robot
K3lso updates. We have now migrated to 20.04 (Focal Fossa) and we are up an running UPXtreme-RT-kernel.
You find updates notes here:https://github.com/raess1/UPxtreme-RT-kernel-20.04
Join us this weekend for the Reddit Robotics Showcase!
https://t.co/D7XUB2t8k0
#k3lso #quad #leggedrobotics #quadruped #UPXtreme #robotics #cnc #milling #ROS #ROS2 #pybullet #bullet @NVIDIAEmbedded @Reddit @hackadayio @hackaday @UPbridge_gap #AI #realsense @IntelRealSense https://t.co/TW7WKABpUN
I'm a little obsessed with the details, here is the new Circlips from #Misumi on the custom milled dowelpin for the chain tensioner 🤓👌
#quad #quadruped #robotics #k3lso #UPXtreme #strongd #chaindrive https://t.co/bS3ExMP0Dx
K3lso with CF covers! Damn happy with the covers!
#k3lso #robotics #quad #quadruped #ros2 #realsense #UPXtreme #UPVision #d435 #design #carbon #fusion360 #tmotor #mjbots #MIT #cheetah #milling #cnc https://t.co/eJ3HK5lbWB
These are the components on the inside of #k3lso
#robotics #UPXtreme #jetsonnx #vectornav #realsense #d435i #d455 #t265 #mjbots #ssd #intel #pcan #can #quad #quadruped #bec https://t.co/36TCs2RiZo
First test of top/bottom carbon cover! Fitted perfectly!
Hi, could you give some details around the control system for the motors?
I believe the AK10_9 have their own control board so I don't understand the use of the moteus control board
Is this puppy ready for sale? I like the way he looks, but I don't know what his function is. Can it be compared with Boston?
What a pity! Many of my friends are interested in four-legged robots, but they just don't want to make one themselves, so I'd like to ask if you have any plans to sell it.so I want to ask if you have any plans to sell it. And I have a question, which way is your robot controlled, and how is the control effect?
This is awesome. Do you plan any AI models to use for navigation. What chip do you use for the "brain" part?
Thanks! I am not quite there yet. :) for brain UP Xtreme i7C1-8565U with UP Vision Plus X ( 3x Myriad X)
Great project. Could you tell me how do you want to manufacture the cover of the robot. It will not be bent sheet metal, am I right?
Thanks! They will SLA printed. you are correct no sheet metal :)
What rubber did you use for casting the rubber? Did you use any mould release for the 3dp moulds? Awesome work!
What sort of Rubber product did you use for casting? Any brand?
Do you have access to all this stuff at work or do you know any reasonable producer here in sweden? I've found that all plastic producer wants insane prices for the most simple parts, got a quote on 85tkr the last day for just one mold.
wow this is awesome and beautiful, i like the evil black and red look even more then the boston dynamics look
Great project! Where is the video where it get kicked around by humans and then hunt them down? I guess the software and movement part is actually the hardest.
haha thanks! It will run cheetah mpc controller to start.
This is incredible stuff not sure why it doesn't have thousands of followers. Love seeing the updates!
Whoa, incredible! Of course the milled parts are spectacular, but the rubber parts that you cast look amazing. Looking forward to following along on what is certainly a long journey ahead ;-)
This project and your progress is incredible! Are you working full-time on this project? Or how do you realize this complex project this fast?
Thanks for the kind Words! Nah. only on my spare time as a hobby ( a few hours every night) :)
Great looking build! Have you got any ideas about the software you are going to use to control it?
Impressive work. Is this a commercial endeavour, is it open source? I can't even imagine how many hours of design and CAD work this took. Following!
At the moment only for fun :) But I guess it will be open source in the end. ;) Thanks!
Pavel Surynek
Ahead
I love this project! Congrats to your work! I have a technical question, though: I see that you are running ROS2. On which level did you implement it (torque control, position control, path planning,...)? Are you running any real-time controllers in ROS? Thanks for your answer
