NOMAD Quadrupedal Robot
Medium-sized 12-DOF Quadruped Robot inspired by MIT Cheetah and Boston Dynamics Spot Mini
NOMAD is a medium-sized 12-DOF high performance dynamic quadruped with expected similar performance to MIT cheetah robots. Powered by custom 8118 BLDC motors/controllers. The size is roughly half way between the MIT Cheetah mini and MIT Cheetah 3 with a mass of approximately 18kg with batteries.
Robot mass: 18kg with Batteries
Body Dimensions: 650mm L x 160mm H x 400mm W
Leg link length: of 280mm
Lower leg actuation: 1.4:1 chain drive
Joint Actuators:  (12) Custom NOMAD BLDC QDD Actuator
More details to come!
  • BIG UPDATE!!
    Implemented Robotics12/29/2021 at 23:58 6 comments
    After a bit of a lengthy hiatus on the NOMAD project things have started to progress again.  Personal life, and *real* work life have been extremely busy on the backend of this year.  While the project was not completely shutdown as I worked out subtle design details in preparation for the final build push nothing of note too much worthy of a project log update.  However we are now ready to update the status, and should look for many more frequent updates as I start building on a more regular basis.
    This update will just be a quick update to share some outsourced machined parts I have received for the upper leg portion.  As well as miscellaneous pulley, sprockets, and tensioner parts.  Ohh also got the feet recast in a softer durometer.
    What's in the package?
    - Upper leg parts (This is constructed in 2 halves to ease manufacturing and assembly)
    - Updated Drive Sprocket (10T)
    - Drive Sprocket Adapter (Facilitates mounting Drive Sprocket to the Actuator)
    - Molded Rubber Foot  (45A Shore Hardness)
    - Knee Joint Chain Drive Parts
        - This includes Chain Tensioners (LH/RH Threaded), Link Pins, Coupling Rod, as well as a new Super Light 11S Chain
    I will post more detail of each of these parts in the not too distant future...  For now see pictures below:
  • Work Still Ongoing
    Implemented Robotics05/13/2021 at 00:59 0 comments
    Sorry it has been a while since I have updated the project log.  Work is still ongoing and you can check the progress (including some leg testing + hopping!) on the Implemented Robotics Instagram.  Stay tuned for more detailed updates soon!
  • Leg Test Stand Parts and Assembly
    Implemented Robotics02/27/2021 at 01:57 0 comments
    After quite the lengthy wait thanks to the big winter storm throughout the US last week I finally got my parts order from OpenBuilds.  With these parts here it is time to build the NOMAD leg test stand!
    OpenBuilds items always come well packed.  Not a single marred surface to be found:
    Bad thing about well packed items is that it takes FOREVER to get everything cracked open!  Still ways to go after getting through that first layer:
    Whew.  That was a chore to get those parts out.  Here they are laid out and ready to start assembly:
    Started with the base first and here it is assembled:
    I always question my order of operations when dealing with extruded aluminum.  Next time I may go with the drop in T-Nuts to avoid planning having the right amount of T-Nuts in all the correct channels before they get closed off from assembling other parts.  Anyway after a few back and forths here we it all assembled with the leg on the linear track.  All that is left now if to get the E-Stop switch, wiring and controller done to run some stress tests.  Getting REALLY close to seeing some physical moment!
  • Leg Testing Stand Concept
    Implemented Robotics02/20/2021 at 22:31 0 comments
    Now that the first prototype leg has been assembled it is time to do some testing of the full leg sans hip motor.  This is to make sure our communications loop between control pc and the motor controller is correctly closed and working.  Also it will help to shake out any bugs in the math for our trajectory setpoints.  The weather has stalled the shipment of the parts to build the stand.  But hopefully when things thaw out over the next few days they will arrive!
  • First fully assembled leg prototype!
    Implemented Robotics02/19/2021 at 18:10 0 comments
    Very exciting to finally get all the parts in and machining finished so that I could finally fully assemble a prototype leg.  Couple of hiccups here and there but it will be fully usable for performance testing and the initial Shakedown cruise.  Once I fix a few assembly bugs I'll document how it is assembled.
    Pictured Below:
    • Custom NOMAD QDD Actuator with 10T drive sprocket
    • Preassembled lower leg with molded foot, bearing and 14T driven sprocket
    • Upper leg structure
    • Shoulder mount
    • Miscellaneous fasteners and washers
    • Off the shelf 11s bike chain
    • Chain break tool to shorten the bike chain
    Here is the fully assembled leg:
    Close up of the in-line chain tensioner mechanism:
  • Upper Leg Machining
    Implemented Robotics02/18/2021 at 21:24 0 comments
    Here are some project progress photos of machining a prototype for the NOMAD upper leg design.  It is done in 2 halves that are joined together and then attached to the shoulder mount.  I will eventually make a proper fixture plate for these operations as the vise overhang + jack stand is a little too precarious!
  • Parts Arrival!
    Implemented Robotics02/18/2021 at 00:01 0 comments
    Shipment has arrived from China!  Includes several parts that I didn't feel like allocating resources/time to machine in my shop and the prices were very fair.
    - Lower leg part
    - Knee Sprocket (14T)
    - Driver Sprocket (10T)
    - Knee Shafts
    - Custom sized 1mm thick shims (These are very hard to find off the shelf.  Can be 3d printed as well)
    Time to move forward on leg construction!
  • Shoulder Mount Machining
    Implemented Robotics02/16/2021 at 18:42 0 comments
    Machining one of the NOMAD shoulder motor to leg mounts.  Was a tricky operation with 5 setups.  I will optimize the rest of them!
View all 8 project logs
Rich text editor
Dimitri wrote 04/04/2022 at 18:21 point
Excited to see where this ends up! Its cool that you outsourced the casting.
Maakbaas wrote 04/04/2021 at 14:55 point
High quality work, I am very curious where you will end up :). Good luck!
