All components of this build:
- Cal. 30 ammunition case
- IP5328P_v1.0 pre build charging circuit from ebay
- 40x 18650 Cells 2AH each
- 5x 18650 4-cell holder from ebay
- 40x Fuse-Holder
- 40x 3A glass fuse
- 80x 20mm M3 spacers
- 5x custom designed PCB
A modular 64Ah power bank from salvaged 18650 cells featuring USB-C (PD, QC, 18watts) to power smartphones and laptops
Hey
in the current version all cells are connected in parallel and the PCB is just doing the electrical connection. You can only add and remove cells if the have the exact same voltage/charge otherwise you will blow a fuse or damage the board/cells.
I would love to add more logic to the board in the future so that you are able to add and remove cells on demand and also build a powerbank with 8 volts or 12 volts.
But this is something for the next versions ;)
