Add a headphone jack for the FC3000.
After uploading the instructions, I changed some images and corrected some typos.
View project log
The available room is about 8-9mm in height, so the one I picked was 8.5mm and I bent the pins to fit it without problems.
This was the item:
https://www.ebay.com/itm/382841364175
You should look for SMD parts, otherwise size will be too big.
Your mileage may vary depending on what you buy.
See my other project for this:
FC3000 disassemble instructions
Desolder the speaker from the PCB:
If you have a multi-meter, check the resistance, should be 8 ohms if your speaker is like mine.
The wires and the connection point are very fragile, don't abuse them or they will probably break.
View all 12 instructions
Shashi Suman
edsjac
Pavel
roelh
Yes, delete it Cancel
You are about to report the project "FC3000 Headphone jack mod", please tell us the reason.
