VHDL/Verilog to Discrete Logic Flow
Work in progress: Flow to synthesize VHDL/Verilog code into a PCB
timTim
The availability of cheap PCB manufacturing and assembly services seems to have sparked a renewed interest in designing digital circuits and processer from discrete transistor based logic. Now, why not go a step further and automate this process?
The final goal is to take VHDL/Verilog source and to turn this into design files (Gerber, P&P, BOM) that allow to manufacturing this design on a PCB.
There is nothing like building actual hardware from your design. FPGAs are a bit boring, ASICs still too expensive, so why not go discrete?
The Flow Architecture
Github repository: https://github.com/cpldcpu/PCBFlow
  • More Logic Family Validation
    Tim01/02/2022 at 14:52 3 comments
    Catching up on an additional round of synthesis test - from last year. I already implemented some changes after observing issues, so this is just an intermediate step.
    I combined counter implementation in four different logic families into one board of efficiency.
    1. RTL_2369: Resistor transistor logic with PMBT2369 and RL=RB=1kOhm
    2. RTPG_2369: RTL+Pass Gate Logic with PMBT2369 and RL=RB=1kOhm
    3. RTPG_3904: RTL+Pass Gate Logic with PMBT3904 and RL=RB=1kOhm
    4. Hybrid_3904: NMOS+Pass Gate Logic with 2N7002 and PMBT3904, RL=RB=1kOhm
  • Analog Multiplexer Logic - Second Attempt
    Tim12/06/2021 at 22:17 0 comments
    Next try at analog multiplexer logic: In addition to fixing the bug in the latch, I also added a few optimizations to the logic style: DFF are now taking only 4 amux and I introduced a few additional gate types (ANDN2, ORN2) that helped to reduced logic complexity. As a result, the counter now only takes 21 amux ICs, instead of 26 before. Furthermore, decoupling capacitors are automotically inserted now.
    Pure AMUX logic
  • Analog Multiplexer Logic and post layout extraction
    Tim11/21/2021 at 00:21 0 comments
    The flow is, of course, not limited to resistor-transistor-logik. In the meantime, I implemented analog multiplexer logic and already received a first PCB with the counter implemented in that logic style. The generated PCB is shown below. The analog multiplexers (BL1551) come in a tiny SC70 package and leave ample space for routing. The implementation of logic gates with multiplexers is quite efficient, hence only 26 devices are needed.
  • Hardware Verification
    Tim11/17/2021 at 23:47 0 comments
    The fully assembled PCBs arrived a bit quicker than expected. Time for some testing.
  • Getting Actual Hardware Made
    Tim11/09/2021 at 19:58 0 comments
    At some point everything has to be put to practice. So, today was time to order some assembled PCBs to check whether the flow actually results in working circuits.
  • 3 Transistor Latch -> 7 Transistor DFF
    Tim11/09/2021 at 19:43 2 comments
    One issue of the logic style I am using currently is that a D-Flipflop takes up no less than 15 units cells, 15 transistors, 30 resistors. This has a huge impact on design size and it would be great to do something about it.
    Months ago, I had a nice discussion with Yann on the TTLer HaD chat and we were competing in trying to reduce the number of transistors in a latch as much as possible. One amazing contraption that came out of this is the design below, that would certainly deserve a more detailed treatment than I can offer here.
  • Footprint Generation - PCBPlace.py
    Tim11/06/2021 at 23:44 0 comments
    After having figuring out where the cells are supposed to go, we need to figure out how to turn them into actual components on a PCB and write them out in a format that can be interpreted by a PCB design tool. As always, I spent most of the time looking for "shortcuts" and only started implementation then.
  • Placement - PCBPlace.py
    Tim11/05/2021 at 21:37 0 comments
    Finally coming to the tricky part - the placement. The purpose of the placement step is to assign physical locations on the PCB to every unit cell that was generated during synthesis. Cells cannot just be placed randomly, their placement has to be optimized according to various creteria.
  • Logic Implementation and Analog Simulation
    Tim11/03/2021 at 20:32 7 comments
    Basic logic gate implementation
    The synthesis step transforms the digital circuit into a spice netlist based on logic cells. To complete the circuit and allow analog simulation we have to actually implement the logic on devices level.
  • Synthesis and Technology Mapping
    Tim11/03/2021 at 19:04 2 comments
    This is where things get a bit more interesting. I was concerned that it was quite difficult to coerce Yosys into using my custom gate libraries, but in fact it was rather easy.
    The "cmos" example proved to be an excellent blueprint to creating a custom library. My logic family of choice is Resistor-Transistor-Logic (RTL), which is based only on resistors and transistors. Coincidentally, this is the same logic family that is used in the famous CDC6600 supercomputer. The basic logic element of RT-Logic is a NOR gate. Hence our design has to be implemented using inverters and NOR gates only. In addition, a storage element, a D-Flipflop, is needed.
View all 14 project logs
victor.ezekiel wrote 10/24/2022 at 13:02 point
This is awesome. However, there is something I cannot seem to figure out. How did you convert the splice net-list to a schematic that can be used to generate the routing and 3d board.
Yann Guidon / YGDES wrote 11/17/2021 at 21:14 point
Your page https://hackaday.io/project/180839-vhdlverilog-to-discrete-logic-flow/log/200258-3-transistor-latch-7-transistor-dff is gone, was this circuit a failure ?
Tim wrote 11/17/2021 at 21:48 point
I accidentally saved it as a draft. The 3T Latch works perfectly.
Yann Guidon / YGDES wrote 11/17/2021 at 22:07 point
phew !!! I was worried :-D
One reason to worry is that certain bipolar transistors exhibit avalanche when reverse-biased, sometimes at quite low voltage, like 2V or less, which makes them unsuitable as pass transistors.
Testing the AF240
More characterisation
I tested old Ge transistors that behave this way, then the behaviour disappeared with more modern Si parts, but the latest RF/microwave transistors might have some reverse breakdown in the "unusable range" again as they trade speed for robustness.
I'm eager to read your report on this story !
Tim wrote 11/19/2021 at 22:47 point
Yeah, HF transistors are usually pretty sensitive to higher voltage. Especially Ge ones. Luckily the MMBT3904 is rather robust and appears to work in reverse operation as well, although at lower hfe.
Yann Guidon / YGDES wrote 11/17/2021 at 14:57 point
If you can do a DFF (in 7 transistors ?), you can do a shift register and a Johnson counter. From there, you can do ser/des (UART ?) and counting/clockwork.
A clock would be the first thing one does with that technology, right ?
Tim wrote 11/17/2021 at 19:13 point
Sure, anything can be synthesized.
joan lluch wrote 08/21/2021 at 08:02 point
Wow, that looks to me as a very challenging and difficult project. It would definitely be extraordinary if you eventually figure it out !
Tim wrote 08/21/2021 at 09:04 point
It turns out that the part VHDL -> spice netlist of RTL logic  was actually comparatively easy and doable with Yosys. I have some scripts that do that automatically now.
I have been ponderings for a while about the best approach for place and route - e.g. abuse some of the FPGA tools out there (NextPNR, Verilog to Routing / VTR) or base it on an actual IC flow (OpenLane). Currently it looks like the latter is more accomodating, but the existing opensource tools are really archaic.
