555ENabled Microprocessor
A Microprocesser designed in a digital logic family based on the NE555
timTim
I found an interesting remark in the 555 timer contest description:
 "Should have used a 555." It's mostly applied where a microcontroller and some code are used where a simple 555 circuit would have sufficed.... Maybe you turn the comment right back around and design a microcontroller based on 555s."
This sounds like a challenge! Let's see how far I get. Definitly should not use an NE555 (or 500 of them) for this.
Update: Success!
Click here to view project logs in order
NE555 logic is now proven to be functional in hardware. Check out the companion project.
NE555synth.zip
Synthesis output
x-zip-compressed - 1.74 MB - 12/11/2021 at 13:49
Download
  • Finally - A CPU
    Tim • 12/11/2021 at 13:45 • 0 comments
  • Post Layout Simulation, Testing Actual Designs
    Tim • 12/11/2021 at 12:13 • 0 comments
    Again, it turns out that introducing post-layout simulation was a very good thing. I found a bug in the cell library that caused the counter to fail after placemenent. Everything works now!
  • Microcell implementation
    Tim • 12/11/2021 at 09:03 • 0 comments
    Now that we managed to define the logic gate implementation and synthesis into a netlist, it is time to figure out how to implement the gates on a PCB. The placementtool PCBPlacer.py in PCBFlow does this by breaking down logic gates into microcells that represent very basic circuit unit. The rationale is to create a minimum set of microcells to simplify the desing. A secondary contrain is that each microcell should be roughly square shaped so that they can be arranged in a grid.
    Currently supported gate types:
    • NOT
    • NAND2
    • NAND3
    • NAND4
    • D-Flipflop
  • Analog Simulation of Synthesized Design
    Tim • 12/07/2021 at 21:24 • 0 comments
    It's nice to simulate individual gates, but better the check whether they work together as well. I created a spice library describing the individual gates the I simultated in LTSpice before. The description of the NAND gate and Latch can be seen below:
    .SUBCKT ne_NAND2 A B Y
    XU1 N001 N002 N001 VCC Y NC_01 VCC 0 TLC55X
    C1 N002 0 1n
    C2 VCC 0 100n
    R1 VCC N001 {RL}
    D1 N001 A RTL_DIODE
    D2 N001 B RTL_DIODE
    .ENDS ne_NAND2
    .SUBCKT ne_LATCH E D QN
    XU1 N001 N002 N001 VCC QN NC_01 VCC 0 TLC55X
    C1 N002 0 1n
    C2 VCC 0 100n
    R1 N001 0 {RL}
    Q1 D P001 N001 0 RTL_NPN
    R2 VCC N001 {RL}
    R3 E P001 {RL}
    .ENDS DLATCH
    Simulating the synthesized design turned out to be quite an ordeal. The TLC555 spice model makes extensive use of parametrised switches. This are described differently in different versions of spice, specifically LTSpice and NGSpice. I found adoption of the TLC555 spice model to both NGSpice and LTspice. Somehow I did not manage to get the full counter design to simulate properly with NGspice due to problems with the operating point analyises.
  • Plugging into PCBFlow - Synthesis
    Tim • 12/05/2021 at 18:29 • 0 comments
    Good thing I already have a design-flow to transform digital designs in exotic logic styles into PCBs: PCBFlow.
    Now that all basic gates of our NE555 logic technology have been defined, I can start implementing the necessary technology description files to implement it into the flow.
    The first step in the flow is the synthesis, which requires a description of the basic gates as a liberty file.  The description of NOT and NAND2 gate is found below. The area designates the number of NE555 required to implement this gate.
  • NE555 based latches
    Tim • 12/05/2021 at 18:00 • 0 comments
    Latches and D-Flipflops have cause the biggest headache in every logic familiy I have implemented so far. This is no different with NE555 based logic. A straightfoward way would, of course, be to form a polarity hold latch out of 3 NAND2 gates. This would require 3 NE555, however, and seems to be a bit of a waste.
    The NE555 has an integrated RS flipflop, meaning that a single NE555 should be sufficient for a latch. What is a bit tricky is to gate the data with the enable signal, so that the RS flip flop is either set for input=1 and EN=1 or cleared for input=0 and EN=0.
    In the end I found a hacky way, using an NPN transistor as a pass gate. Since the NE555 logic is slows anyways, it does not matter that the pass gate is quite slow as well. The circuit is shown below.
  • Spice Simulation of Combinatoric Gates
    Tim • 12/05/2021 at 13:27 • 0 comments
    Testing more detailed gates will be easier in spice. First step is to replicate the inverter. Testcircuit shown below.
  • Some Experiments: Building an Inverter and NAND gate
    Tim • 12/05/2021 at 11:23 • 0 comments
    It appears my NE555 are from a few kits I ordered on Aliexpress a while ago. They have some kind of distorted TI logo on them, so I am pretty sure they are not genuine devices, but they should work nevertheless. Time to pull out the breadboard. The resistor capacitor network you can see on the right side is to set the level of my function generator correctly to 0/5V.
  • First Assessment
    Tim • 12/05/2021 at 10:07 • 0 comments
    Ok, I may have played around with the NE555 years ago and also owned some kind of circuit book for it.  But I always only copied circuits from somewhere else. So, time to study its details a bit more. It's not my first obscure logic style, so we ought to find something, right?
    The block diagram of the N555 from the TI datasheet is shown above. What do we get on a functional level? Two comparators with fixed thresholds, an RS flipflop with reset input and an output driver. The threshold input should be good to act as switch for an analog summing input network and the RS flipflop could become part of a latch. This does not look too bad. CONT and DISCH are probably not too useful for logic circuits, but we will see.
    The functionality is described as this in the datasheet:
    I don't get why the RESET voltage threshold is not listed. Luckily it is defined later in the datasheet:
    A minimum of 0.3V appears quite low. This means that no diodes or anything causing a large voltage drop may be between the reset input and ground. Something to keep in mind for later.
    Ok, all in all this does not look too bad. We can probably construct both registers and combinatoric logic out of the NE555 and some additional components. In the mean time I also found some NE555 lying around. So let's get to some experiments.
View all 9 project logs
Yann Guidon / YGDES wrote 05/30/2023 at 02:03 • point
Hi @Tim ! would you share your .Liberty file for this amazing technology ? I don't find it in the .zip file :-/
Tim wrote 05/30/2023 at 05:25 • point
In the meantime I removed this technology again from.pcbflow, but you can find everything in the github commit history
Yann Guidon / YGDES wrote 12/18/2021 at 01:24 • point
Maybe you can repurpose your synthesiser to Redstone/Minecraft ?
https://www.youtube.com/watch?v=R_Tocwnk9ws
Yann Guidon / YGDES wrote 12/18/2021 at 00:46 • point
You've been HaDed again !
https://hackaday.com/2021/12/17/implementing-a-cpu-using-555-timers-and-logic-synthesis/
Tim wrote 12/19/2021 at 08:03 • point
Wow, nice! Somehow I totally missed this one.
Yann Guidon / YGDES wrote 12/15/2021 at 17:13 • point
Does this mean that the 555 is Turing-complete ????
Tim wrote 12/15/2021 at 17:58 • point
I guess in the same sense that the transistors in a CDC6600 are? :)
Yann Guidon / YGDES wrote 12/15/2021 at 14:37 • point
So are you trying to do the inverse of https://hackaday.io/project/183013-attiny555 ?
Tim wrote 12/15/2021 at 18:00 • point
That is indeed the question. Maybe I could use the emulated NE555 in lieu of a real one in the design above? NE555 turing inception.
Yann Guidon / YGDES wrote 12/17/2021 at 05:52 • point
I believe you should go ahead, yes.
teraz wrote 12/13/2021 at 11:16 • point
this will be compatible with 4004 or zx spectrum?
a couple extra 555s should fix that.
No, it's a much simpler CPU with only 4 instructions.
Yann Guidon / YGDES wrote 12/11/2021 at 21:54 • point
TIM ! You shamelessly broke the Internets again !!!!
Tim wrote 12/11/2021 at 22:29 • point
Well, I think I completed the rite of passage of building a circuit with a NE555 :)
Yann Guidon / YGDES wrote 12/15/2021 at 14:33 • point
You did. Now I hope you win the https://hackaday.com/2021/12/01/the-555-timer-contest-returns/ :-P
