Moving firmware PC simulation from a Qt app to a web application
07/20/2026 at 09:59 • 0 commentsI've developed a new simulator of the firmware for my hardware data logger. It allows me to build and test my high-level layer of firmware logic for STM32 on a PC, without wasting time flashing the device. The previous version used Qt as a frontend, now it's web-based and containerised inside Docker. I've found that Qt is hard to containerise, requires remote desktop, and plenty of packages to install, and the user experience is not so great. IMHO, the web is the modern way :) Also all is in Docker (except web browser).
The idea is that the firmware driver layer that uses HAL on the hardware can be exchanged in a PC-based build with an equivalent that instead exposes all actions/events via methods/callbacks, and then this PC variant is compiled to a .so instead .elf. The two driver layers don't inherit from a base class - instead I've used cpp20 concepts to save on firmware size (no vtables).
Then there is a web server (FastAPI) that uses this .so, and this is driven by the user's actions sent via REST by the web browser. So for example, when the user clicks Start in webpage, the server will periodically call the tick() method as the real hardware TIM interrupt would. If the user clicks the simulated hardware button, the server will call a method in the driver layer so that the next time the firmware checks the button (GPIO pin) it's marked as clicked. The firmware doesn't know it is being simulated.
There is also a need to get the state from the firmware and show it to the user. This way it is possible to visualise, for example, what the firmware wrote to the SD card in real time. For that, the .so has a set of callbacks that are set by the simulator before startup, and when an event occurs the callback in the driver layer is called, the server sends this info and associated data over WebSocket and the frontend shows it to the user.
Disabling heap usage in CMake.txt
07/12/2026 at 16:54 • 0 commentsThe usage of heap is generally not wanted in embedded projects and I tried to follow this practice and not use any data types or algorithms from the std lib or any manual new/delete, so I was thinking maybe there is a way to make an automatic check that will fail the build if it is used? There is.
Here is the trick (maybe there are better ways but it's good enough for me) in Cmake.txt:
add_link_options( -Wl,--wrap=malloc -Wl,--wrap=calloc -Wl,--wrap=realloc -Wl,--wrap=free -Wl,--wrap=_malloc_r -Wl,--wrap=_calloc_r -Wl,--wrap=_realloc_r -Wl,--wrap=_free_r -Wl,--undefined=__wrap_malloc -Wl,--undefined=__wrap_calloc -Wl,--undefined=__wrap_realloc -Wl,--undefined=__wrap_free )How does it work?
- When in cpp or in c a memory is allocated on the heap, at the end somewhere the malloc/calloc or similar function will be called.
- The snippet tells the linker to rename calls to malloc to wrap_malloc, calloc to wrap__calloc, etc. A regular implementation of malloc/calloc won't be used now because the names doesn't match.
- Mark the new wrap_malloc etc. functions explicitly as not implemented (the undefined part) so that even if someone would implement them, the linker wont't use them.
The linker won’t find those functions at linking time and the build will fail if heap is used in the code.
There is one issue here, the linker error won’t tell where the dynamic memory was used. It’s needed to search the map file for printf etc.
My build failed and it took me two hours but finally I found it! The assert() was using dynamic allocation (to prepare the assert message?). Yep, assert() can use dynamic allocation (and it's possible to avoid it, but for me for now it's good enough to just comment the problematic assert since I don’t have any logger to UART/SD card for now anyway).
Now I am heap free :)
I ordered the wrong CH340 chip, but it still kind of works.
01/21/2026 at 12:41 • 0 commentsCH340s are cheap Chinese USB-to-UART chips that are, well… cheap and easy to solder. They come in various variants, where the last letter indicates which exact variant it is (CH340B, CH340C, CH340G, CH340E, CH340R, CH340T). I bought one to make an onboard programmer for an ESP chip here. 20 pieces for 7 euro was a good deal!.
To make a programmer fully automated (no need to push buttons), we need UART and two pins to drive ENA and GPIO0 of the ESP module. The trick is that UART chips have RST and DTR lines that can be connected to those pins on the ESP and then driven by the flashing tool on the host PC.
So far, so cool - except that I bought a CH340E, and it’s the only one in the family that doesn’t have a DTR pin :P
So I have to push a pin on the board manually to flash the device (at least only one, because the RST pin is there and that part works fine).
In the next revision I will use CH340X and follow this tutorial - it seems that with this version there is no need for extra transistors logic (but I will left place for them on the PCB anyway)
Nevertheless, the programmer is working - just not in a fully automated way. So for a first try, I’m kind of okay with it.
​Flashing and debugging STM directly from a docker container makes setup easier.
01/18/2026 at 18:52 • 1 commentI have tried to use docker heavily to make automatic setup of tests etc., but there was still one and most important thing that I couldn't do - at the end of the day it's an embedded project and the chip needs to be flashed, debugged, etc. Configuring this from Docker to be easily clickable from VS Code seemed hard. Also there is a need to access physical devices (USB based programmers for STM/ESP chips) from the docker image which seemed hard too.
Finally I made it possible and this post is about this.
Pros
- Installation of all tools is automated, no need to manually install on a host PC a compiler, tools to debug, flash, etc.
- No conflicts between versions of toolchain between different projects, all is inside a Docker container. No error-prone environment variables etc.
Cons
- At the startup of VS Code one needs to click to switch to docker container in Visual Studio Code, it's annoying.
- When using USB devices (here it's ST Link programmer for example) they need to be mapped to Docker image each time they are plugged in. I've just bought a cheap USB hub to have many USB sockets to avoid the need to disconnect the device.
tl;dr - is it worth it? I would say 50:50.
Now let's get to details, we will need:
- Docker desktop
- Visual Studio Code
This manual is for Windows. While docker in theory hides host OS specific subjects... well not always. When dealing with hardware or for example line endings, we will have host OS specific issues.
We need to have Docker desktop running, then we install in VS Code the "Dev Container" extension.
Now we need in the root directory of the project to add this configuration: .devcontainer/devcontainer.json
{ "name": "STM32 Logger Development", "dockerComposeFile": "../docker-compose.yml", "service": "dev", "workspaceFolder": "/workspace", "customizations": { "vscode": { "extensions": [ "ms-vscode.cpptools", "ms-vscode.cmake-tools", "twxs.cmake", "ms-vscode.cpptools-extension-pack", "ms-python.python", "rust-lang.rust-analyzer", "vadimcn.vscode-lldb" ] } }, "postCreateCommand": "echo 'Dev container ready! Open HardwareDataLogger.code-workspace'", "shutdownAction": "stopCompose", "containerEnv": { "DISPLAY": ":0", "WAYLAND_DISPLAY": "wayland-0", "XDG_RUNTIME_DIR": "/mnt/wslg/runtime-dir", "PULSE_SERVER": "/mnt/wslg/PulseServer", "QT_X11_NO_MITSHM": "1", "QT_QPA_PLATFORM": "xcb" } }This will tell the "Docker Container" extension which docker image we want to build (note the location of the .yaml file, service and workspace - those are the important things, the rest is not very important).
Now we can restart VS Code and click on the icon "><" in bottom right and from the palette on the upper center select "Reopen in Container". The VS Code will restart.
We are now running VS Code inside the container, meaning when we build, flash, debug, etc. we are using toolchain from the docker, not from host PC. The configuration of toolchain to debug, flash, etc. is as usual in VS Code (at least I think - I still learn it so I will not post about it for now, I'm still trying to make it user friendly).
There is one caveat: each time we connect our USB device we need to mount it to the Docker. To do this, open PowerShell as administrator, then:
PS C:\WINDOWS\system32> usbipd list Connected: BUSID VID:PID DEVICE STATE 2-3 0020:0b21 USB Audio, USB Input Device Not shared 2-5 27c6:639c Goodix MOC Fingerprint Not shared 2-6 0c45:6739 Integrated Webcam Not shared 2-10 8087:0033 Intel(R) Wireless Bluetooth(R) Not shared 4-1 0483:3748 STM32 STLink Shared 4-4 046d:c52b Logitech USB Input Device, USB Input Device Not shared
Our debugger is 4-1 in this example, we will bind it:
PS C:\WINDOWS\system32> usbipd bind --busid 4-1 usbipd: info: Device with busid '4-1' was already shared. PS C:\WINDOWS\system32> usbipd attach --wsl --busid 4-1 usbipd: info: Using WSL distribution 'docker-desktop' to attach; the device will be available in all WSL 2 distributions. usbipd: info: Loading vhci_hcd module. usbipd: info: Detected networking mode 'nat'. usbipd: info: Using IP address 172.24.192.1 to reach the host. usbipd: info: Firewall check not possible with this distribution (no bash, or wrong version of bash).
Now in Visual Studio Code (launched as above) let's check if it's visible:
root@b9c51a95e012:/workspace/Software/STM32F103RBTx# lsusb Bus 001 Device 001: ID 1d6b:0002 Linux 6.6.87.2-microsoft-standard-WSL2 vhci_hcd USB/IP Virtual Host Controller Bus 001 Device 006: ID 0483:3748 STMicroelectronics STM32 STLink Bus 002 Device 001: ID 1d6b:0003 Linux 6.6.87.2-microsoft-standard-WSL2 vhci_hcd USB/IP Virtual Host Controller
That's it we can now use toolchain from Docker to work with the firmware, no need to install it on host PC and it can be integrated with VS Code GUI.
Execution time from 1h to 4 minutes - CI time on GitHub.
01/07/2026 at 19:14 • 0 commentsLong story short, it's about parallelization and the use of cache.
The context is that a year ago I made many CI jobs to test and verify the quality of the code and one of them uses CodeChecker, a powerful but RAM/CPU-greedy tool. This was because my machine isn’t powerful enough to run it locally (even though the project’s codebase is small). This way, I could push to GitHub and the CI job would verify code quality and give me results as an HTML file.
It was good -GitHub gives a lot of CPU/RAM power for free- but over time I added more code to check (I was thinking: why not statically analyze unit tests too? It's weird but why not :). And I didn’t know when it happened (build was always failing due to linter's findings). Recently I saw that the build was failing because it was killed by GitHub due to RAM/CPU usage!! There were no results either, so the whole idea of crunching the data remotely failed.
I tried to optimize and finally I’m happy with the results: 1h -> 4min. But there were many steps to make it work. They are more or less in chronological order.
Optimize Dockerfile
I removed what I no longer need (for me it was include-what-you-use, because well, I will no longer include anything - I will use C++20 modules anyway, but that’s a different story). Using multi-stage builds where the most frequently modified parts are at the end can help too. Good to cleanup but this didn’t give me a lot.
Split GitHub's CI .yaml files into multiple ones
The syntax of the .yaml GitHub uses is a huge boilerplate. The indent-based nature of .yaml doesn’t help either. I was just not capable of fixing one big yaml. It's like that now. No gains, but very useful for the next step.
Build caching
Saved me 10 minutes—very useful!
The idea is that if the Dockerfile was not modified from a previous build, it will not be rebuilt - a cached copy of what was built will be used.
It works in a way that the principal build does the building if needed; other jobs wait for it. If no changes for me it takes ~20 sec. If there were changes (very rare), full build, me me its ~10min. Because I almost never update Docker file I almost always finish in the first case so I'm now saving 10min (previously it was always 10 minutes).
One negative is that each of those parent jobs will have their build artifacts with them. There is no single place to get all build artifacts from a commit. I would prefer to have a tree-like structure with a node as a build name and subnodes of build artifacts.
Matrix jobs
This doesn’t speed up things but is helpful in the next steps. This avoids boilerplate code in .yaml, as a simplified example:
strategy: fail-fast: false matrix: include: - name: Business Logic make_target: test_biz - name: Device make_target: test_dev steps: - name: Run Unit Tests run: | "cd /workspace/build && cmake -G Ninja -DCMAKE_BUILD_TYPE=Debug .. && ninja ${{ matrix.make_target }}"Parallelize the static analysis
This is the game changer with execution down to 4 minutes!!
The thing is CodeChecker uses compile_commands.json, generated by CMake. I have a "main" CMake that includes parent CMakes, and CMake will just put every cpp/hpp used by any projects he is able to build inside compile_commands.json.
We need separate compile_commands.json for every executable and run parallel builds for each of those executables. It's not eassy to generate compile_commands.json, but I've found a trick gow to make it:
We can run CMake like that (note that I use ${{}} trick from previous step):
cmake -G Ninja -DEXPORT_SINGLE_JSON=${{ matrix.target }} -DCMAKE_BUILD_TYPE=Debug .. && ninja CMakeFiles/cstaticThen in the CMake I have:
if(DEFINED EXPORT_SINGLE_JSON AND EXPORT_SINGLE_JSON STREQUAL "${TARGET_NAME}") message(STATUS "Enabling compile_commands.json export for: ${TARGET_NAME}") set_target_properties(${TARGET_NAME} PROPERTIES EXPORT_COMPILE_COMMANDS ON) endif()This works and it's the main point of this post :)
Swap for Docker image in case we run out of RAM
I added it just in case in yaml file (note that it can't be more than 4G or GitHub will fail to run the job):- name: Enable Swap Space
run: | sudo fallocate -l 4G /swapfile sudo chmod 600 /swapfile sudo mkswap /swapfile sudo swapon /swapfile free -h
Limit CodeChecker jobs
Use --jobs 1, TBH, I don’t know if, with all the modifications above, higher values couldn’t be used for some jobs.
COMMAND CodeChecker analyze compile_commands.json --output ${CODECHECKER_ANALYZE_DIR} --file ${CODECHECKER_SOURCE_DIRS} --skip ${CODECHECKER_SKIP_FILE} --jobs 1That's it all is on GitHub, CI is failing due to ongoing other refactor.
Avoid vtable, big RAM/flash gains, upgrade to C++23
01/04/2026 at 19:08 • 0 commentsI've gained 5.97% (9584 bytes) of flash and 8.29% (1696 bytes) of RAM, mainly by completely removing usage of virtual functions, but probably also because I've moved to C++23 and used its features and updated GCC to the latest stable version (because C++23 is still a bit under development on the GCC/Clang side).
In this post I will give a cool example of how I've avoided virtual functions and used (a bit pointlessly but it's in compilation time) modern C++23 features.
The thing is that I've structured my application into three layers: BusinessLogic, Device and Driver. All HAL related code is in Driver. There I have for example SdCardDriver, UartDriver and other classes that wrap/hide low level hardware subjects.
Previously I've created for each of such class an abstraction class, so I had ISdCardDriver, IUartDriver etc with all pure virtual methods.
For the build of the firmware, the Driver's classes inherited from it (and implemented its methods using HAL's methods). For the build of PC simulation (the firmware for testing and simulation can be run on PC, no need for hardware, I've presented this in previous entries) I have a different set of Drivers that implemented the same abstraction classes (and they provide mocks too).
Depending on whether I was building binary for ARM or binary for PC I've switched the compiler and the Driver folder that I used so the correct set of drivers would be used.
So far so good, it works and is correct, but now all those methods are virtual and it adds a bit of time of execution and binary size (under the hood compiler adds virtual table and in runtime checks what methods it should call).
I've realized that I could do better :)
Now I don't have those abstraction classes at all, I didn't need them. Build for ARM has its folder with hpp/cpp that uses HAL and build for PC has its own too. The idea of switching folder with drivers depending on build type stays the same. Common logic (like enums etc.) that are used by both AR/PC variants were extracted to common headers so that there is no duplication.
And that could be the end but C++23 has a nice feature... concepts.
An example of concept from project's code:
template <typename T> concept SdCardDriverConcept = std::derived_from<T, DriverComponent> && requires(T driver, std::string_view filename, FileOpenMode mode, std::span<const std::uint8_t> data) { // File operations { driver.openFile(filename, mode) } noexcept -> std::same_as<SdCardStatus>; { driver.write(data) } noexcept -> std::same_as<SdCardStatus>; { driver.closeFile() } noexcept -> std::same_as<SdCardStatus>; };For each driver I've added concept that checks (during compilation) if the driver implements all needed methods, for example:
class SdCardDriver : public DriverComponent { //... }; static_assert(Driver::Concepts::SdCardDriverConcept<SdCardDriver>, "SdCardDriverConcept must satisfy the concept requirements");It's a static assertion. It's not needed here, if one class doesn't implement all that is needed the build would fail anyway, anyway nice to have it.
Before all those optimization:
Memory region Used Size Region Size %age Used RAM: 6608 B 20 KB 32.27% FLASH: 35916 B 128 KB 27.40%After:
[22/22] Linking CXX executable HardwareDataLogger_STM32F103RBTx.elf Memory region Used Size Region Size %age Used RAM: 4912 B 20 KB 23.98% FLASH: 28088 B 128 KB 21.43% -
HW rev 4.1
01/02/2026 at 16:50 • 0 commentsThe new HW version has many minor fixes. Some of them are interesting, so I'll share them in this post.
First, the USB connector used for the power supply ripped off, and I don't have a soldering iron here, so the device doesn’t work. lol. The thing is, micro USB is small, its pads are small (mostly surface-mounted), but the forces when the cable is plugged, unplugged, or moved are huge.
The fix is to make much bigger pads for soldering the shield of the connector, so the mechanical stress is better dissipated. This is shown in the image below (original USB connector from KiCad libraries vs. the new one I made).
Second, I added a proper STLINK connector to the PCB. In the previous version, I just added a pin header but didn't care which pin was which, so I later had to use wires to connect the device to the programmer. It was annoying and looked lame. BTW, I also added a dent so the STLINK can only be inserted the right way.
The STM chip on the device always uses its own power supply; it's not powered from the STLINK. In case that could be a problem (I don't think so, but who knows-I have a cheap STLINK clone), I added an LED on my PCB between the STLINK's 3V3 and GND. It’s used to simulate the STM’s power consumption and as an indicator that the STLINK is connected.
Third, I switched the ESP. It's no longer an ESP8266 but an ESP32-WROOM-32E. This is because I want to write its code in Rust, and Rust doesn't support the ESP8266 as it's an old chip.
To make flashing the ESP easier (as with the STM, wires are error-prone), I've added on the board a USB programmer for the ESP. It's based on the CH340X, which I find very cool because it's much cheaper than an FTDI chip and easy to get in an easy-to-solder package. An extra feature I added is two LEDs to show the state of RST and GPIO0 - this should be helpful for debugging whether the flashing is working at all.
he circuit is as bellow, it's not tested.
Fourth, all cards are now 1cm shorter while keeping all the previous functionality. I realized all those PCBs next to each other looked so empty - there was so much unused space on the boards.
I also added TVS diodes to ESD-protect the device from whatever is connected via the UART and pulse counter connectors. The diodes are added to all the pins on the SD card as well.
Short update
12/27/2025 at 21:01 • 0 commentsThis is a short update, I will post technical details in next posts:
- I reworked PCBs, now they are 1cm shorter as well as fixed some other annoying things found in previous version
- Static analysis CI build went from 1 hour (and killed by GitHub CI so no results) to 4 minutes
- I think about using GUIslice (https://github.com/ImpulseAdventure/GUIslice) as a GUI lib because it supports RGB displays.
- ESP code will be done in Rust, simply because I hate Arduino libs; STM32 code is C++.
- Made a PoC for processing data on Raspberry Pi and showing data via Graphana (more info here: https://hackaday.io/project/198074-piweathershield in project description, manual is here: https://github.com/RobertGawron/HardwareDataLogger-RemoteProcessing/tree/main/Target)
- Massive refactor of the project's structure.
Using docker context for easier deployments on RasberryPI
09/14/2025 at 16:04 • 0 commentsI have reworked the part of this project related to the visualization of the collected measurements via the web interface. Now it's easier to deploy to Raspberry Pi and better documented. I've also cross-tested it with data from my other project because the code for the ESP32 in this project is still not finished.
Previously, I planned to use Ansible to deploy the Docker images to the Raspberry Pi, but I found this tool to be overkill. Instead, I found something much easier, but with its limitations: docker context.
The idea is that normally (without changing anything) Docker deploys containers on the local machine (where it runs). This can be changed, however, thanks to contexts. All that is needed is to generate SSH keys to access the remote machine without a password and then, on the local machine, run:
docker context create pi --docker "host=ssh://user@host_to_deploy" docker context use pi
Now we build locally but deploy, start containers, and debug them remotely.
It's super easy, but there is a problem. I use prebuilt Docker images for all the building blocks, and when I deploy them, it deploys just the images. All local files from the repository (including configuration) are not deployed because they are not part of those images (Docker downloads them from the Internet). That means that the images are not configurated.
Later on, I just log in to each of the images (Node-RED, InfluxDB, and Grafana) via web browser (I have chosen the software in a way that all can be configured via web browser) and configure tokens, etc. I’ve explained this in the manual. So the configuration of the containers is not in the Git repo and needs to be done again when deploying to a new machine. But it’s easier and good enough, I think.
Normally, when a container is restarted, its content reverts to the original state, meaning all modified files are reset. That wouldn’t be good here because after each such restart, I would need to reconfigure everything. But fortunately, there’s something called Docker volumes. It’s possible to configure which file locations are persistent between restarts.
What’s even more interesting is that AFAIK those volumes are available as a regular folder on the host machine, in this sense on RasberryPi, because that's where they are installed.
I think I could create a private repo with a backup of those folders, private because in theory it contains sensitive things like authentication tokens. That way, if the SD card of my Raspberry Pi fails and I need to recreate the OS image from scratch later on, I can just deploy using docker context and apply the volumes, therefore restoring the old configuration.
Another thing that would be possible with Ansible but isn’t possible with Docker contexts is that I can’t preconfigure the Raspberry Pi - for example, manually install Docker on it. I need to do it manually now.
Maybe in the future I will return to the idea of using Ansible, but for now, it's good enough for me as it is.
Assembling hardware version 4.0
06/28/2025 at 10:32 • 0 commentsIt's been a long time since I posted anything here, but I've started building the new version. While the software remains the same, the new hardware is built in a modular way. There's a main board with multiple parallel slots (each one is identical) and cards that can be plugged into it.
The cards are:
CPU: STM32 board with some minimal peripherals
Storage: ESP32 that will send data outside, SD card slot
Acquisition: BNC connectors, UART connectors
HMI: display, keyboard, phototransistor to detect how much to dim the display at night
The idea is that, in this way:
if one part needs changes or redesign, the other parts can still be used
new boards can be added in the future
PCB manufacturing in China is so cheap these days that it's economically reasonable
Robert Gawron
