SMD reflow hotplate
simple smd reflow hotplate
based on *MCH Metal Ceramic Heating* elements
the dream of my home made smd reflow tool...
i had varying results with some classical pizza oven version and *cheap smd ovens* used in hackerspaces / fablabs around..
and i wanted to have something that needs little space when not in use.
in the project log you find the full story...
current status: basics working :-)
Build a Hot-Plate / Heating-Element based reflow tool for SMD PCB soldering.
Hardware
ToDo: description of used Hardware
for now have a look at the used parts.
Software
ToDo: describe how the software works
Tools
Installation
  • update CircuitPython to at least v7.0.0
  • copy all the needed files to your CircuitPython drive.
  • create profile that fits your needs and copy to drive.
Usage
  • power up controller
  • power up psu for heating
  • connect serial terminal (GTKTerm)
  • connect and setup plotting tool (SerialPlot)
  • in the serial terminal you have a basic menu with some options..
  • tune your PID for your setup
  • select profile to use with *pn* or the hardware *Select* button
  • click on the hw *start* button
  • in the serial terminal the profile configuration is shown
  • start reflow cycle with a click on hw *start* button
  • wait...
  • if finished the plot should stop automatically (no data is send)
  • save plot
  • click on *start* to confirm and get back to standby state
Open Points
  • add housing
    • i would like to have class at the top for a good view what is happening inside..
  • metal frame for heating-elements
  • quite 5V fan with PWM control for cooling
  • add second temperature sensor
  • spring thing to hold board down
  • way to fix sensor position on board
  • more heating elements for bigger working area
    • switchable configuration for long or more square pcbs?!
  • bigger power supply ?! (~750W)
  • fix short heating powerup on microcontroller reset
  • 1 × Haljia 24V 110W Wired MCH Metal Ceramic Heating Plate Heating Element 70mm x 15mm
  • 1 × MeanWell GST280A48-C6P (uuhh - that is underpowered for bigger pcbs...)
  • 1 × recom R-78HB50-05 VIN: 9-72V VOUT: 5V
  • 1 × IRLB4030PBF Discrete Semiconductors / Power Transistors and MOSFETs (N-LogL 100V 180A)
  • 1 × BC 550C Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
View all 9 components
  • actual soldering
    Stefan Krüger01/09/2022 at 00:06 0 comments
    this morning i did a last test-run with the tweaked Felder ISO-Cream profile:
    yeah... at the top i thought it is in the cooling step already and opened the window - with ~3°C cold air from outside it dropped fast.. then i found it is in the middle of the reflow - sorry... and closed the window again - until it really switched to cooling..
    the old left-over pcb i use for these is done now.. i comes from my LEDBoard_4x4_16bit project - and if i remember correctly i backed it while assembling the  boards in the oven multiple times back then.. now grilled it again ~4-7 times. it smells very bad - is super dark discolored.. i think that is ok with about ~12 solder cycles..
    and then started to assemble a simple board to really test the profile :-)
    placed
    then reflowed:
    i added a paper-lid to have stable air inside..
    reflow was successful :-) my profile is just a little bit to long for my right angle touch switches:
    they melted away :-( - lesson learned - have a look in the datasheet and you know that they are very heat sensitive!
    in general i have the feeling that my heating elements get a little bit to hot - the pcb also slightly discolored at on place...
    so will keep an eye on this and improve it..
    Open Points
    • add housing
  • Testing and Tuning the PID
    Stefan Krüger01/08/2022 at 11:32 0 comments
    for tuning i followed more or less the tutorial PID Without a PhD from Tim Wescott and the tutorial and video from PID Explained Team.
    first i just checked with low temperatures of 20..40°C as i went on and tested up to 260°C i noticed that the current did decrease. and the temperature did not increase any more. i could see this in my graph as the heating got slower and slower with the rising temperature… (also the pid already saturated at the output..)
    so i measured the resistance during the cool down of the heating elements to get some insights: (4x in series → 48V/4=~12V/Module)
    Resistance (Ohm)Power @48V (W)
    4057
    3958
    3859
    3660,5
    3860,3
    3464,8
    2688,6
    2496
    22104
    20,9110
    19,5118
    Temperature / Resistance – 4 Modules in Series – 12V/Module
    result: the ~57W is not enough to get to more than 255°C…
    i rearranged the Modules into 3-in-series connection. this means ~16V/Module – and tested again:
    27,570
    27,072
    26,677
    25,680
    25,382
    24,186
    18,8100
    17,5130
    16,7
    15,6
    14,3
    Temperature / Resistance 3 Modules in Series – 16V/Module
    with this i found that i can go above 255°C.
    i then tested the profile for the Felder ISO-Cream “Clear” and found that in the reflow stage the heat-up is a little to slow:
    config:3S profile:Felder ISO-Cream “Clear”
    my setup
    in the *my setup* picture is a temporary cardboard thing with a 80mm 12V fan (connected to 5V) to cool down faster between tests. for the final setup i think i will buy 1 or two 5V and PWM capable fans…. and also exchange the *chamotte* ston with some metal frame. this way i also can cool the bottom side..
    so i again switch the configuration – now i have a 2-in-series config: 24V/Module CURRENTLY THIS TABLE IS ONLY CALCULATED VALUES!!
    20115
    19,5118
    19121
    18128
    17,5132
    17135
    13177
    12192
    11209
    10,45220
    9,75236
    CURRENTLY ONLY CALCULATED VALUES!!!! Temperature / Resistance – 2 Modules in Series – 24V/Module
    i also tested this with the Felder profile:
    this time the heat-up is fast enough! 🙂 the nice and working pid tuning i had for the 4-in-series arrangement is now out of tune… so i will have to re-tune it to get less overshoot / swing.
    while having a break i thought about the maximal power in this configuration – and found that this way i only be able to power 2×2 modules with my 250W power supply. for now i leave it this way. in the long run i hope with the other frame concept i get more heat to the pcb and less into the stone and this way be able to use the 3S config.
    Tuning
    after a day of mostly waiting til the system cooled down again – one test cycle <=60°C needs 400s → 6:40min – i just rebuild my hw mounting setup.
    • new setup
      new setup
    • details of mounting
    this way i can warm up quicker and cool down much quicker as i do not store heat in the stone. – at least that is what i hope..
    plot old setup
    plot with old setup
    plot new setup
    plot with new setup
    hmmm – does not seem to change much..
    i then tested the actual Felder Profile:
    Felder ISO-Cream ‘Clear’ – Sn96,5Ag3,0Cu0,5 – 2S1P – P 04.50 I 00.00 D 00.00
    seems i have a working profile. i will add a little more time for the prepare phase. so the pcb is really fully at the 50°C. at the top i have a little bit of a mis-match – i saw on my temp sensor directly connected to the heating elements at the top ~265°C – so that is hot… the pcb seems to increase its temperature resistance at higher temperatures… at the peak i have 230°C to 245°C error. and to the heating this results in ~35°C difference…
    i will report when i solder the first real board. 😉
  • progress
    Stefan Krüger01/08/2022 at 11:01 1 comment
    there was a response to my request in the forum: with the links to
    i have created a [new repository for my cp_reflow_controller – with this example on hand i will use a adafruit PyBadge as main controller – and use the EZ-Make-Oven as guide how to design the software… (all the parts i have on hand are a little bit different….)
    As temperature sensor i use the Adafruit MAX31855 Thermocouple breakout board
    parts have arrived and i have build the hw..
    and over the holidays i also have written the firmware...
    and just *along the way* written a CircuitPython library for nonblocking user input...
    with this setup i can experiment with the PID...
  • the first steps...
    Stefan Krüger01/08/2022 at 10:54 0 comments
    the idea came from this Applied Science Video: Electroluminescent paint and multi-channel control circuit 21 Nov 2018 starting at 11:25
    there is a link to amazon for a element – and it is not available to delivery to germany 🙁 so i went on with some help of friends and found
    voltagecurrentpower@ 6Vpower@ 12Vlink
    12V5,8A17W70WHALJIA 12V 70W Wired MCH Metal Ceramic Heating Plate Heating Element 70mm x 15mm
    24V4,6A7W27WHaljia 24V 110W Wired MCH Metal Ceramic Heating Plate Heating Element 70mm x 15mm
    12V4A12W24WHaljia 12 V48 W Wire MCH Metal Ceramic Heating Plate Heating Element 40 mm x 40 mm
    24V424W48WHaljia 24 V96 W WIRED MCH Metal Ceramic Heating Plate Heating Element 40 mm x 40 mm
    to get an idea of how much power i actually need i had a look at the small commercial IR-Heaters and Hot-Plates – they all have about 800W:
    180mm * 235mm = 42300 mm² = 423 cm²
    a = 60mm * 60mm = 3600 mm² = 48 cm (1x4)
    b = 60mm * 80mm = 4800 mm² = 48 cm (2x2)
    c = 60mm * 90mm = 5400 mm² = 54 cm² (1x6)
    d = 60mm * 120mm = 7200 mm² = 72 cm² (1x8)
    e = 120mm * 60mm = 7200 mm² = 72 cm² (2x4)
    f = 120mm * 90mm = 10800 mm² = 108 cm² (2x6)
    g = 120mm * 120mm = 14400 mm² = 144 cm² (2x8)
    423 cm² == 800W
    1 cm² == x
    x = 800W *   1cm² / 423cm² = 1,89W
    a = 800W *  36cm² / 423cm² = ~68W (1x4)
    b = 800W *  48cm² / 423cm² = ~91W (2x2)
    c = 800W *  54cm² / 423cm² = ~102W (1x6)
    d = 800W *  72cm² / 423cm² = ~136W (1x8)
    e = 800W *  72cm² / 423cm² = ~136W (2x4)
    f = 800W * 108cm² / 423cm² = ~204W (2x6)
    g = 800W * 144cm² / 423cm² = ~272W (2x8)
    30x40mm: ~23W/module
    60x15mm: ~17W/module
    then i calculated the resistance of the found element to check on what wattage i can do at what voltages:
    U = R*I
    P = U*I
    → P = U*(U/R)
    (i added these *guesses* in the table above)
    So I decided to go with the 70x15mm 24V model. and will update here if i found how this works out..
    and for the first test setup i will go with the concept 12V→ 27W / module so definitive more then enough..
    as power supply i will use a MeanWell GST280A48-C6P (reichelt) with an fitting connector (reichelt) to get a 5V for the controller i will go with a recom R-78HB50-05 (VIN: 9-72V) and for switching the power to the heating elements i will use IRLB4030PBF – MOSFET N-LogL 100V 180A 370W 0,0043R TO220AB and to drive this a BC 550C as mentioned in this nice article: Schalten und Steuern mit Transistoren III – Mit MOSFETs höhere Ströme schalten
    so when all the parts arrive i can go on.. with building.
    for the Controller i plan to write it in CircuitPython and run it on an adafruit ItsyBitsyM4. and maybe later add an LCD – or use a PyBadge – for now i just want to use the arduino serial plotter or similar with an second CDC-device enabled to log the progress and the flash-drive function of CircuitPython for a text-file with the temperature-profile. i have written a request in the adafruit CircuitPython forum if there are any PID controller things out there…
View all 4 project logs
