Small size actuator 67x48 with 5.4:1 reduction ratio and dual encoders.
1231.PNGPortable Network Graphics (PNG) - 337.68 kB - 02/08/2022 at 22:56 |
demo1.pngPortable Network Graphics (PNG) - 4.21 MB - 02/08/2022 at 22:56 |
Sensorless FOC testing. This baby got some speed! Hitting ~ 530RPM (end of video)
#bldc #quadruped #robotics #robot #RLS #Cubemars #KittActuator #Actuator #tmotor #design #quad #quadruped #robotjoint #Robots #vesc #foc https://t.co/CacXr5McKa
DJ spin that enconder..
Parts for rev2 have arrived (left in picture). Will do some assembly with motor and gear tonight
Second version soon ready. ;)
Back covers ready and looking sharp!
First assembly test spin 🙃
#bldc #quadruped #robotics #robot #RLS #Cubemars #KittActuator #Actuator #tmotor #design #quad #quadruped https://t.co/40TZt2YRKX
Alot of progress today. Got the gears today.
Some pics from the assembly
Next version is cooming together.
Test assembly of the carrier.
So the MRA049 ring (Magnet for RLS) is press fitted on the output.
Then the output is press fitted on the carrier and then screwed together.
The housing have a NSK 6705 bearing. The output is resting on the OD of the bearing.
A bit overkill. The housing also have room for a NSK 6703 bearing which the carrier is resting on. This is to minimize any type of movement on the output if any extended load is placed on the output.
Then each of the carrier (pc1 / pc2) parts have a internal BR106 bearing which the drive shaft is resting on.
(still wating for gears)
Spin Unicorn spin!
I have to say, the name intrigues me...
I assume you're developing this for, erm, non-automotive applications, though? ;)
The name is just a name (reference to knight rider.) :) applications is non. Bulding for the fun of it.
You just keep delivering incredible designs! Awesome! I am already curious to learn about the technical details!
Hello! First of all, I have to say that this is an awesome project, I like it :) I have a question: how can you assemble the rotor of RI60 with the output shaft? It seems that the RI60 rotor doesn't have holes for the screws!
