21/2
02/21/2022 at 14:43 • 0 comments -
21/2
02/20/2022 at 23:03 • 0 commentsSome minor mods on the back cover and housing.
Also working on the rev6 tonight (Future version)
Some redesign to skip the splitted output / carrier parts. Also increased the gear width by alot doing it this way (~66%). Some bearings needed to change to have the abilty to fit the new sun pattern diameter for the 6.85:1 reducation. The planets still remains 17T.
02-15
02/15/2022 at 14:51 • 0 commentsHad some time to finish the front and back cover on rev4.
02-14
02/14/2022 at 19:55 • 0 commentsAllright, today I got my Nylon PA11 - MJF printed form factor parts (The rev2 version) and everything fitted like a glove.
The milling have started (The Rev4 version) for all parts except back - front cover in 7075 and will be ready in about two weeks. I chose to run 4 sets (4 - Actuators ) and 50% black oxide parts and 50% gold oxide parts, so I can mix and match with the color scheme. :)
I have also placed an order for more bearings from NSK & NTN and additional miscellaneous titanium screws that will be needed in later assembly.Simple test:
02-11
02/11/2022 at 22:33 • 0 commentsNot much like this has happened since last time.
I have worked with drawings and tolerances.
The gears for the planetary gearbox is now on milling order. I went with C45 and 25-30HRC heat treatment and black oxide! It should arrive in 14-days.
I did a small revison on the bearing width hole on the Planets. Incearings it slightly to 2.3mm to be able to fit the 682U-H from NSK.
The gear setup is:Ring: 44T
Planets: 17T
Sun: 10T
Now lets finish the rest of the parts! -
08-02
02/08/2022 at 23:36 • 0 commentsSpent a few hours tonight with adjusting symmetry for cut-outs and hole patterns. I love symmetrical designs where ever it is possible.
I also redesigned the carrier, planet gears, added space for optional bearing, new front cover. Adjusting the output slightly.
I also did some static load testing to see how the output will handle overhang (mounting) from the bearing since the magnet ring for the (AksIM-2) have a ~0.2mm "ride height" which means that this part needs to be rigid for the possible loads that may arise. Results ok.
Anyways with the new changes I was able to hit my 50mm goal (happy ~48mm) I name this version Rev3.
For the prototype I will also remove the housing fins.
In a few days I will also receive a full sets of mjf printed parts (Rev2) to play with (Formfactor print only).
Hardware status:
Arrived: Bearings, dowelpins, titanium screws.
Ordered. RI60, AksIM-2.
Milling: on hold.
