Hackaday.io Hackaday.io
Sign up Log in
Kitt actuator
Small size actuator 67x48 with 5.4:1 reduction ratio and dual encoders.
robin-frjdRobin Fröjd
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.8k views
5 comments
53 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 0
  • Logs 26
    • View all
  • Instructions 0
  • Discussion 5
View Gallery
3.8k
5
53
28
Team (1)
  • robin-frjdRobin Fröjd
Join this project's team
  • Build blog
  • LinkedIn
ongoing project
BLDC actuator Robotics
This project was created on 02/04/2022 and last updated 5 years ago.
Description
Kitt -D67
- Weight: ~ 350 (g)*
- Height: 48 (mm)
- OD: 67 (mm)
- Reduction ratio: 5.4:1
- Rated Torque: ~ 2.75 (N.m)*
- Peak Torque: ~ 8.8(N.m)*
- Max Speed: ~ 530 (RPM)*
Will update more information here shortly.
Follow the build here: https://quadrupedalism.com/d/44-kitt-actuator-wp-project/33
Files
Portable Network Graphics (PNG) - 337.68 kB - 02/08/2022 at 22:56
Preview
Portable Network Graphics (PNG) - 4.21 MB - 02/08/2022 at 22:56
Preview
Project Logs
Collapse
  • 04-15
    Robin Fröjd • 04/15/2022 at 11:46 • 0 comments
    Sensorless FOC testing. This baby got some speed! Hitting ~ 530RPM (end of video)
    #bldc #quadruped #robotics #robot #RLS #Cubemars #KittActuator #Actuator #tmotor #design #quad #quadruped #robotjoint #Robots #vesc #foc https://t.co/CacXr5McKa
  • 04-07
    Robin Fröjd • 04/07/2022 at 20:51 • 0 comments
    Testing the RLS AksIM-2 setup
    DJ spin that enconder..
  • 04-05
    Robin Fröjd • 04/05/2022 at 18:51 • 0 comments
    Parts for rev2 have arrived (left in picture). Will do some assembly with motor and gear tonight
  • 03-22
    Robin Fröjd • 03/22/2022 at 14:41 • 0 comments
    Second version soon ready. ;)
  • 03/10
    Robin Fröjd • 03/10/2022 at 14:22 • 0 comments
    Back covers ready and looking sharp!
  • First assembly test spin
    Robin Fröjd • 03/09/2022 at 17:56 • 0 comments
    First assembly test spin 🙃
    #bldc #quadruped #robotics #robot #RLS #Cubemars #KittActuator #Actuator #tmotor #design #quad #quadruped https://t.co/40TZt2YRKX
  • 3/9-2
    Robin Fröjd • 03/09/2022 at 14:36 • 0 comments
    Alot of progress today. Got the gears today.
    Some pics from the assembly
  • 03/09
    Robin Fröjd • 03/09/2022 at 14:21 • 0 comments
    Next version is cooming together.
  • 03/08-2
    Robin Fröjd • 03/08/2022 at 10:55 • 0 comments
    Test assembly of the carrier.
    So the MRA049 ring (Magnet for RLS) is press fitted on the output.
    Then the output is press fitted on the carrier and then screwed together.
    The housing have a NSK 6705 bearing. The output is resting on the OD of the bearing.
    A bit overkill. The housing also have room for a NSK 6703 bearing which the carrier is resting on. This is to minimize any type of movement on the output if any extended load is placed on the output.
    Then each of the carrier (pc1 / pc2) parts have a internal BR106 bearing which the drive shaft is resting on.
    (still wating for gears)
  • 03/08
    Robin Fröjd • 03/08/2022 at 08:26 • 0 comments
    Spin Unicorn spin!
View all 26 project logs
Log In/Sign up to comment
Sign up with Github
OR
hmtuan wrote 06/12/2022 at 20:22 • point
Hello! First of all, I have to say that this is an awesome project, I like it :) I have a question: how can you assemble the rotor of RI60 with the output shaft? It seems that the RI60 rotor doesn't have holes for the screws!
Starhawk wrote 02/09/2022 at 06:23 • point
I have to say, the name intrigues me...
I assume you're developing this for, erm, non-automotive applications, though? ;)
Robin Fröjd wrote 02/11/2022 at 22:24 • point
The name is just a name  (reference to knight rider.) :) applications is non. Bulding for the fun of it.
rraetz wrote 02/04/2022 at 17:59 • point
You just keep delivering incredible designs! Awesome! I am already curious to learn about the technical details!
Robin Fröjd wrote 02/05/2022 at 16:34 • point
Thanks!
The 2018 Hackaday Prize
This is Quadbot 17, a work-in-progress quadruped robot with 22 degrees of freedom, based on Robotis AX-12 motors and a 3D-printed chassis.
Project Owner Contributor
Quadruped robot with 22 DoF
dimitris-xydasDimitris Xydas
A 3D printed robotic leg, inspired by Boston Dynamic's Spot Mini robot. Aimed to balance form and function
3D Printed Quadruped Leg
adamstibiljadam.stibilj
A maker friendly capstan based BLDC driven quadrupedal robot kit.
Stanley - the capstan based quadruped kit
aheadAhead
RR1 is an open-source, 6+1 degrees of freedom desktop robotic arm, mostly 3D-printed with joints powered by custom planetary gearboxes.
RR1: Real Robot One - a DIY Desktop Robotic Arm
pavel-surynekPavel Surynek
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Kitt actuator", please tell us the reason.
Send message
Remove Member
