DuePrint Sample Print
10/23/2022 at 05:39 • 0 commentsAnother Sample Print of a tooth brush holder using the DuePrint.
Print Speed Test
07/22/2022 at 00:54 • 0 commentsPrint Speed Test Results. 0.2 mm layer height, initial print speed 90 mm/s, increasing print speed observed resulting in what is likely acceleration limited print speed for most of the print at print speed setting of 240 mm/s. Minimal print vibrations observed. The extruder can out extrude the print movements!
Speed Test Print Quality
07/21/2022 at 12:44 • 0 comments![]()
90 mm/sec at base. 300 mm/sec at top. Printing is acceleration limited and likely never reaches 300 mm/sec. There interesting thing is that it is nearly impossible to out run the extruder, meaning the extruder can push out more melted filament than the printer can move to extrude it. Check videos to see it in action.
Test Print
07/21/2022 at 12:29 • 0 comments![]()
Test Print showing print quality using 3rd party ABS filament.
Jeremy
