The next questions I will be addressing in the near future are as follows:
- How can backpropagation be implemented?
- What would happen if one uses quantum logic gates?
Since the error can also be only 0 or 1, the occurrence of an error means that the inverted input vector must be true. This would then be the backpropagation.
M. Bindhammer
Yann Guidon / YGDES
Al Williams
Gómez Mora Rodrigo Uriel
This is interesting project and idea... If I had a digital perceptron with 9 inputs and 5 outputs, how many samples would I need to present it to teach is that inputs are A+B+carry and output is Y+carry out?
