The next questions I will be addressing in the near future are as follows:
- How can backpropagation be implemented?
- What would happen if one uses quantum logic gates?
Since the error can also be only 0 or 1, the occurrence of an error means that the inverted input vector must be true. This would then be the backpropagation.
M. Bindhammer
Gómez Mora Rodrigo Uriel
Al Williams
This is interesting project and idea... If I had a digital perceptron with 9 inputs and 5 outputs, how many samples would I need to present it to teach is that inputs are A+B+carry and output is Y+carry out?
