Wasting holes on breadboard
12/19/2016 at 05:11 • 0 commentsWhen trying to put a wire into breadboard right next to the adapter, there is not enough room for those pre-made cables with plastic support at the ends. So, I see two possibilities: make the joining block taller [easy] or rotate the ESP block so the ESP is on its side (or end) [harder, but may be more practical in use].
And since another version is on the radar, make the walls of the ESP socket slightly wider at top to allow better jamming in of the ESP module.
