Image 2 4/23 - 4/30
05/01/2023 at 18:01 • 0 comments -
Image 1 4/23 - 4/30
Week of 4/16 - 4/23
04/28/2023 at 19:09 • 0 comments- Had trouble running the dockerfile, still working it out
- Added more images to the basecamp file depicting expiration codes
- Decided to switch off of Scenetext recognition to license plate recognition, as Scenetext has proven difficult to manage, license plate recognition did not work
- Started new method, which began to work well, and eventually got it to recognize text from a picture!
- Began setting up the lights, had an issue, still figuring it out, started looking for youtube videos that could help us.
- Finished incorporating the months into pythonanywhere code, our code can now read the month of the year and determine if it is expired or not,
Week of 4/23 - 4/30
04/24/2023 at 18:18 • 0 comments- Got the formula down for the python code, just need to do a lot of coding to add in all the months and dates, etc.
- Continued researching for the light aspect
- Tried running the python code, but it was flawed, still checking. Eventually got it working correctly.
- Finished the python code! It can now correctly recognize dates, and compare them. When we press a key, the file runs, and we want to make it run when we take a picture.
- Became stuck on finding a correct light.
- Got the camera to work
- Ended up still using scenetext recognition, got some errors and got stuck
- continued to work on lights, but got stuck because we could not get neo lights working, and we started using the breadboard for the LEDs
- GOT THE LEDS WORKING! They blink on and off, and we have figured them out FINALLY.
Image 2 4/16 - 4/23
04/24/2023 at 18:12 • 0 commentsDidn't get an actual picture of the program, but this is a drawing that shows very closely to what the program can do so far.
Image 1 4/16/23 - 4/23/23
04/24/2023 at 18:00 • 0 comments -
Images for 4/9 - 4/16
04/17/2023 at 18:27 • 0 comments -
Week of 4/16 - 4/23
04/17/2023 at 18:04 • 0 comments- Had trouble running the dockerfile, still working it out
Week of 4/9/23 - 4/16/23
04/11/2023 at 18:38 • 0 comments- Gained access to a jetson nano, with password and username.
- Created hackaday.io, started documenting our weekly progress using logs.
- Began looking on NVIDIA to find code that would be efficient for the reading of text, tried out code, seeing if it would be sufficient, found code that looks promising.
- Brainstorming logistics, and strategies, etc.
- Started downloading code for our program
- Added images to basecamp depicting expiration dates for our AI
