11Relay assembly
A 2 Channel DC 5V Relay Module with Optocoupler
$6.79 on 9/19/2023 -
12The hardware build
Putting it all together is probably the funnest part. Use your best judgement of how to arrang everything, or simply use the images as a guide. I've found that standoffs are you friend...
https://www.amazon.com/gp/product/B06Y5TJXY1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Remember how great you are at this, and never doubt your abilities!
13The wiring
This is another fun stage. Follow the schematic, checking off each connection made. If you are as I and have limited use of your hands, consider things that make it easier, such as solderless connections...
https://www.amazon.com/gp/product/B08J7M8X49/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
This jewel's pin spacing is exactly as the Pico's breakout board, making the connection to it super easy...
https://www.amazon.com/gp/product/B07D8QCZQL/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Again, remember how great you are at this, and never doubt your abilities!
Stephen Craver
$6.79 on 9/19/2023
