A quick video demo
Table of Contents:
Hackaday dot io single-page view mode gets a bit unweildy for a project of this size, so here's a table of contents:
The most up-to-date design and fabrication files are in the Codeberg Repository.
You can buy an assembled Version 2 driver board on Tindie.
Project Logs document my journey of making this whole thing happen, including quite a lot of learning-process failure. Link opens in chronological order.
Details (this section / link opens page standalone) has video showcases, a walkthrough of the primary "class E" driver, and an overview of the system as a whole.
Instructions features overall recommendations for creating your own plasma toroid, component selection tips, and some notes on replicating the Version 1 build.
Files is OLD/ARCHIVED version 1 design files. and LTspice simulation files
Log #11 covers deficiencies in Version 1, and areas for potential improvement.
Log #14 is an overview of improvements made in Version 2.
Full Video Showcase:
How does the driver work?
Steve Ward explains the circuit's function in terms of what happens on each cycle. That can be a useful way to think about things, but for myself I gained far more intuition about how things work by deconstructing the entire resonator into a series of functional building blocks.
Let's start simple -- take some voltage in (V1), put an inductor (L1) in series with an N-channel mosfet (U2), and feed the mosfet a square wave at some frequency. Areas of the circuit have been highlighted to correspond to the LTspice simulation traces. (Don't worry too much about the specific values on each axis; the overall shape of each trace is more important.)
It's a boost converter!
While the mosfet is conducting, current flows through L1 and builds up a surrounding magnetic field. When the mosfet turns off, this field tries to keep shoving current through L1, resulting in a spike in voltage.
The next building block the beating heart of this project -- a resonant LC tank circuit formed by our primary inductor and a small bank of high-voltage capacitors (Cp).
In this classic LC Resonator tank circuit, energy sloshes back and forth between the electric field in the capacitor and the magnetic field around the inductor. This resonator tank is being fed by the voltage spikes created by L1.
If the tank is driven by a frequency that's well-matched to its natural resonant frequency 1 / ( 2pi √(LC) ), total energy in the resonator accumulates and can greatly exceed the input on any one cycle. The primary inductor's substantial electromagnetic field will excite our xenon.
Trying to precisely match the resonator and gate drive frequencies to match each other sounds annoying and fiddly, so let's use a feedback network instead.
Adding a capacitor Cg (between Cp and ground) forms a capacitive voltage divider. This drives the gate at exactly the natural resonant frequency of the tank circuit. Now the tank is oscillating at 9 amps and (peak-peak) 2.4kV!
Since a capacitive voltage divider only responds to AC, the DC component of the gate drive is set by connecting some bias voltage V(bias) through a resistor. The value of Cg is chosen such that the AC amplitude at the mosfet gives solid turn-on / turn-off without exceeding operational limits, and the mosfet duty cycle is determined by where V(bias) positions this waveform relative to the mosfet's gate threshold voltage.
Rather than plonking down a magic reference voltage for V(bias), let's instead pull a voltage divider down from our supply voltage.
In a physical circuit, let's make R2 a potentiometer so we can freely adjust V(bias) while the circuit is in operation.
The only thing left is to fine-tune the gate drive!
For the real circuit, it is very important that mosfet turn-off occur when the drain voltage is at a minimum, aka "zero-voltage...
What's Changed from V1?
jaromir.sukuba
Dylan
Mastro Gippo
Hello! I wanted to share with you that I built your design and got it working today! Here are some clips https://x.com/chet_wiltshire/status/1913790480875417707
