Phase 1: My goal is to design five PCBs that include resistors, capacitors, active devices and various input and output components. These will mount on a laser cut wood base similar to the original design, but smaller. One of the issues with the original design is the springs would oxidize, and the wires would break. I am planning on using standard breadboard jumper wires with headers on the board to make the connections.
Hi all! If you happen to be at Supercon today I will be doing a lightening talk around 10am on the project. Hope to see you there!!
