The PrintAirPipe System is a 3D printable pipe system. Using the different pipe segments, an individual and customizable exhaust or supply air system can be set up. Ideal for conveying the exhaust air from a soldering station, 3D printer or similar to a suitable filter system or wall outlet.
The PrintAirPipe system consists of different segments that can be individually connected to each other.
There are currently the following segments available:
- Flange segment
- Butterfly valve segment
- 120mm fan insert
- Filter segment
- Adapter to 100mm PrintAirPipe standard
- Adapter to 80mm PrintAirPipe standard
- Adapter to 50mm PrintAirPipe standard
- 90° connector
- 45° connector
- 22.5° connector
- Y-distributor segment
- Y-distributor straight segment
- Extension 50mm
- Extension 100mm
- Extension 150mm
- Extension 200mm
- Cover cap
- and more...
Files & Code:
- The housing stl files are available on my blog at:
- 125mm pipe diameter set: https://nerdiy.de/en/product-2/printairpipe-125mm-rohr-segmente-set-3d-druckbar-stl-dateien/
- 50mm pipe diameter set: https://nerdiy.de/en/product-2/printairpipe-50mm-rohr-segmente-set-3d-druckbar-stl-dateien/
- Complete set: https://nerdiy.de/en/product-2/printairpipe-125-druckbares-be-und-entlueftungs-rohrsystem-komplettset-3d-druckbar-stl-dateien/
- Servo Valve: https://nerdiy.de/en/product-2/printairpipe-125-servo-valve-3d-druckbar-stl-dateien/
- 360° intake segment: https://nerdiy.de/en/product-2/printairpipe-360-intake-segment-3d-printable-stl-files/
- AirFlowSensor segment: https://nerdiy.de/en/product-2/printairpipe-125-airflowsensor-segment-3d-printable-stl-files/
- Air Sensor segment: https://nerdiy.de/en/product-2/printairpipe-125-air-sensor-segment-3d-printable-stl-files/
- Inch Adapter Set: https://nerdiy.de/en/product-2/printairpipe-125-inch-adapter-set-3d-druckbar-stl-dateien/
- 120mm Radial Fan Segment: https://nerdiy.de/en/product-2/printairpipe-120mm-radial-luefter-segment-3d-druckbar-stl-dateien/
- 120mm Axial Fan Segment: https://nerdiy.de/en/product-2/printairpipe-120mm-axial-luefter-segment-3d-druckbar-stl-dateien/
- The ESPHome configuration for all "intelligent" segments are available at my github repo: https://github.com/Nerdiyde/ESPHomeSnippets/blob/main/Snippets/PrintAirPipe/
More Pictures & Videos:
Support:
If you want to support me, you can do so by like on this project page, on Instagram or by donating a coffee. :)
Licenses:
Content that is not based on software/code: Unless otherwise stated, all works presented here that are not based on software/code are subject to the CC BY-NC-SA 4.0 license (attribution – non-commercial – dissemination under the same conditions 4.0 international).
You can find a summary here: https://creativecommons.org/licenses/by-nc-sa/4.0/deed.de
You can find the complete legal text here: https://creativecommons.org/licenses/by-nc-sa/4.0/legalcode.de
Software/code-based works Unless otherwise stated, all software/code-based works presented here are subject to the GNU Affero General Public License v3.0
You can find a summary here: https://tldrlegal.com/license/gnu-affero-general-public-license-v3-(agpl-3.0)#summary
The complete legal text can be found here: https://www.gnu.org/licenses/agpl-3.0.de.html
wilyarti
Moritz Walter
The "complete set" link goes to some eink display frame.
