tape_organ_firmware_v0.3
version v0.3: the tape organ can now be controlled via cv. connect cv according to schematics. set pin 8 to high to enable cv. set pin 7 to have the rp2040 interpret the cv signal from 0-5 volts or to low for 0-10 volts, depending on your hardware. If you use the resistors as shown in the schematics, the rp2040 should be save to use up to 10 volts. (plus some overhead). if you intend to use other CV voltages, you should check the resistors.
3 -
63.00 kB -
04/06/2025 at 17:20
