There's another minibadge standard https://github.com/lukejenkins/minibadge that I seem to have taken inspiration from. The square makes things easier with board outlines. Google saintcon minibadge and you will get some nice examples.
We don't need that many headers to make some LEDs glow and 6 pins on the SAO can already be so confusing when you create your first blinking SAO, especially when everybody mirrors their images to help you (get you confused).
SAOAOs don't have that problem - its mirroring-protected pinout makes it a breeze to route. Ground is on the outside pins, VCC is in the middle. Don't get confused by the SAO adapter though, someone made a mistake with the silkscreen, because + - + looked cute and distracting.
davedarko
mrpendent
Benchoff
El Jefe
blinkingthing
thank you for making this and donating one to me, it made me learn SMD soldering with syringe and heat gun :) https://marc.merlins.org/perso/electronics/post_2024-11-02_Pasadena-Hackaday-Supercon-2024-Yo-Dawg-Micro-SAO-and-SMD-Soldering.html
