1Connect POV Display to Badge
Connect the SAO connector to the badge, taking into account the pin orientation. Once securely plugged in, power on the badge. The POV display should activate immediately, indicated by blinking LEDs. If the LEDs do not blink, double-check the connection and make sure the badge is correctly powered.
2Test POV Display for "SUPERCON8" Message
Move the POV display smoothly from left to right and back again to reveal the hidden message. As you wave it, look closely to see if the message "SUPERCON8" appears in the air.
3Switch POV Display to "Message Uploading Mode"
Firmly double-tap the POV display board to switch it to message uploading mode. If successful, the LEDs will turn solid white instead of blinking. It may take a few tries, and tapping it against a hard surface like a table can help.
4Upload New Message to POV
To upload a new message to the POV display, use the I2C protocol. The device’s I2C address is 0x5B. Follow these steps to transfer your message:
- Prepare the Message:
- The message must be an ASCII character array.
- It can contain up to 12 characters maximum.
- Supported characters include:
- A-Z (uppercase only)
- 0-9 (numbers)
- Space
- Symbols:
- Upload the Message:
- Use buffer write to send the message to memory location 0x00 on the device.
- Ensure the message fits within the 12-character limit. Any extra characters will be ignored. If your message is shorter than 12 characters, it’s recommended to pad the remaining space with SPACE characters to ensure the entire previous message in memory is fully overwritten.
- Confirm Success:
- If the upload is successful, the POV display’s LEDs will begin blinking.
- To view the new message, wave the display left and right. The updated message should now appear clearly in the air.
The following is an example of how to upload the message "HELLO" to the POV Display, using the Arduino IDE:
#include "Wire.h" //Defines #define DEVICE_ADDR (0x5B) // standard Arduino setup() void setup() { //Begin Wire I2C Wire.begin(); } void loop() { uint8_t dataToWrite[5] = {0x48, 0x45, 0x4C, 0x4C, 0x4F}; //HELLO writeI2CBuffer(DEVICE_ADDR, 0x00, dataToWrite, sizeof(dataToWrite)); delay(5000); } void writeI2CBuffer(uint8_t DeviceAddress, uint16_t Address, uint8_t* dataBuffer, size_t dataSize) { Wire.beginTransmission(DeviceAddress); // Begin communication with the I2C slave // Send the memory address starting at 0x00. Wire.write(Address); // Send the high byte of the memory address // Send the buffer data for (size_t i = 0; i < dataSize; i++) { Wire.write(dataBuffer[i]); // Send each byte from the buffer } Wire.endTransmission(); // End communication with the I2C slave }For an equivalent example using MicroPython (Not Tested on actual badge):
from machine import I2C, Pin from time import sleep # I2C device address DEVICE_ADDR = 0x5B # Initialize I2C on Pico W (I2C 0, SDA on GPIO4, SCL on GPIO5) i2c = I2C(0, scl=Pin(5), sda=Pin(4), freq=400000) def write_i2c_buffer(device_address, mem_address, data_buffer): # Create a bytearray with memory address followed by data buffer = bytearray([mem_address] + data_buffer) # Write the bytearray to the I2C device i2c.writeto(device_address, buffer) # Main loop while True: # Data to write: "HELLO" in ASCII (0x48, 0x45, 0x4C, 0x4C, 0x4F) data_to_write = [0x48, 0x45, 0x4C, 0x4C, 0x4F] # Write data to memory starting at 0x00 write_i2c_buffer(DEVICE_ADDR, 0x00, data_to_write) # Wait 5 seconds before the next write sleep(5) - Prepare the Message:
Michael Yim
