POV (Persistence of Vision) displays work by rapidly moving a set of LEDs or lights in a specific pattern while turning them on and off at precise intervals. This creates the illusion of a stable image or text because the human eye retains each light's position for a brief moment, blending the sequence of lights into a continuous visual. The timing and speed of movement are critical to achieving clear and legible visuals.
This particular POV display will have the following tentative specs:
- Hand-wave operated
- ADXL345 accelerometer to detect motion
- 5 front LEDs (probably white)
- 5 back LEDs (probably white)
- Padauk PFC232 Microcontroller to handle the logic
- SAO compatible so you can put it on your badge
- User can use the SAO to customize the display message via I2C
Michael Yim
davedarko
Chris Combs
Ken Yap
Andy Geppert
would be funny if it detects the badge falling and yelling "ahhhhhhhh" on the way down or something :D Cool project :)
