Proof of Concept Tests
10/04/2024 at 22:59 • 0 commentsAs a proof-of-concept to make sure something that this at least semi-works, I quickly put together a ver 0 prototype using an Arduino Pro Micro, an ADXL345 breakout board, a few LEDs and a breadboard. I know the technology works because others have done it before, but I wasn't quite sure if I could pull it off in time.
In this initial test, I attempted to display a simple letter "M" using the POV display. As shown in the video, it somewhat works, but the result isn’t quite as clear as I had hoped. One of the main challenges was getting the LED flashing timed correctly. Synchronizing the LED flashes with the motion proved to be trickier than I anticipated. The timing needs to be precise to create a clear and readable character, and even small variations can distort the letter. This experiment highlighted the complexity of fine-tuning the display to achieve smooth and accurate visuals.
