Camera features
- 256 x 192 pixel resolution at up to around 22 FPS
- Optional distance and temperature/humidity sensors for ambient correction
- Micro-SD Card DCIM storage for JPG image files
- Rechargeable 3.7V Li-Po battery and/or external 5V DC power
- Battery-backed RTC for JPG image timestamp
- [iCam] 3.5" 480x320 pixel touchscreen with GUI interface
- [iCamMini] Wi-Fi mode (AP or STA) with web-browser based GUI interface
- [iCamMini] Video mode with either NTSC or PAL analog output
- Capable of 1-point or 2-point calibration against a known blackbody radiator
GUI Interface
- LVGL based (both iCam touchscreen and iCamMini Web Browser)
- Ten color palettes
- Selectable Min/Max Temperature Markers
- Selectable Spot Marker
- Selectable Region Marker
- Camera Settings
- Micro-SD Card File Browser and image display
Video Interface (iCamMini)
- Selectable NTSC or PAL non-interlaced timing
- 288 x 192 pixel monochrome display with two palettes
- Camera settings using local buttons
Dan Julio
Hi Dan, really cool project. I'm also working with the tiny1-c but because of the poor documentation I'm struggling to get the raw temperature data via VOSPI,
I'm only able to get the image data (YUV422). Would it be possible to provide the register addresses and values they were changed to in order to output the raw temp data?
