« Back to project details
Pressure Regulator Research
01/23/2025 at 20:54 • 0 commentsSpecs
- Inlet pressure of ~800 PSI for CO2 cartridges/tanks
- Outlet pressure to be determined, but starting at 150 PSI
- The smaller the better in terms of wearability
Options
- Paintball gun regulators
- Inlet pressure gauge is 1000 - 4500 PSI
- Ohh! The gauge is only inlet, so it not actually a regulator! Some do allow outlet adjustement.
- Very small
- Unknown flow coefficients
- Unknown outlet pressure
- Not too expensive
- Options
- Polarstar Micro MR Gen2 Regulator (1)
- Max inlet pressure: 1500 psi
- Regulated outlet pressure: 20-200 psi
- Input thread: G 1/2-14
- Vavoger Paintball PCP Airsoft Co2 Tank Cylinder Regulator Adapter DIY Kit (adjustable-range: 0-200psi)
- Preece Precision Series 3000 High Flow Adjustable CO2 Regulator 0-250 psi
- Designed for CO2
- 45 Cubic Feet per Minute (CFM)
- Regulated outlet pressure: 0-250 psi
- Inlet connection: CGA320
- Unknowns: Where to attach gauge
- Industrial regulators
- More expensive
